2010 Civic Hybrid Valve Adjustment
Old Sep 8, 2020
twdeschler's Avatar
twdeschler is an unknown quantity at this point
Hey everyone,
Need some help here getting the valve cover off of a 2010 1.3L hybrid. The 8th bolt in the back corner is seemingly covered and impossible to get to. Does anyone know how to get this off or an easy way to get the arm above the bolt off?
Thanks in advance.
The 8th main valve cover bolt is hidden in the back underneath the wire harness arm.
This valve is tucked under what is holding the wire harness loom in place and I can't get to it.
The reverse is how I figured it needed to be removed and there seems to be one bolt holding it on that is very difficult to get to. It would seems there's an easier way to remove it.
Should I remove this bolt to remove the arm that holds the wire harness or is there a better way to do this?
Grey
Engine DIY
52
Sep 23, 2021 04:04 PM
TUNZ_99EX
Mar 29, 2020 07:51 AM
Andrey Zhdanyuk
Mar 17, 2020 11:56 AM
Fez
Sep 18, 2017 06:44 AM
clawhammer
Nov 8, 2010 09:19 AM
