No start after cvt replacement 2014 Civic
Old Apr 24, 2022
kingsgate's Avatar
kingsgate is an unknown quantity at this point
Angry No start after cvt replacement 2014 Civic
This Civic always started even after sitting for months. After used CVT replacement, engine would crank but wouldn't start. Decided old fashioned reset by disconnect both +/- battery terminals and touching them. Thinking that mechanic should have waited maybe 15 mins after the disconnect before touching them but whats done is done. Problem now is when pushing start button there is absolutely no response, no acc, nothing, (brake pedal depressed). Both fuse mains #1 and 2 are good. Still have to go through other possible fuses for source. Headlights, flashers, horn all work. Tried pushing start button hundreds of times while holding proximity key next to it, still no response. Battery is at 11.6V but used good jump box, no change. Need ideas about which fuse to check or other possibilities. Remember that even when starter cranked it wouldn't start. Dash led display says the normal "depress brake pedal, push start button".
Old Apr 25, 2022
Colin42's Avatar
Re: No start after cvt replacement 2014 Civic
Try charging the battery
purplepills
Electrical
Mar 31, 2020 09:06 PM
esorenson
Engine start problems
Dec 3, 2019 01:13 PM
xj3nt
Buy, Sell, & Trade - Archive
Jan 18, 2010 10:16 AM
greysky
Dec 27, 2006 03:40 AM
gearbox
Feb 27, 2005 02:04 PM
