Engine loses power at 2600-3000 rpm especially going up hills P1861
Old Feb 3, 2021
Katalyst's Avatar
Katalyst is an unknown quantity at this point
2008 Civic Hybrid 1.3L 290000 miles
Code P1861
Just had spark plugs replaced
Was noticing the car was starting to lose power at highway speed while going up long hills.
I took the car into a local mechanic and they replaced the spark plugs.
This helped the issue and I was able to continue commuting to work and even a longer trip to go back home over the holidays.
After getting back from the long trip the issue started to get worse but I was still able to drive the car carefully being mindful of rpms.
Fast forward a couple weeks, the issue has gotten so bad that putting the engine over 2600-3000 rpm make the the car lose engine power/acceleration.
The car can't even get past 20 mph in some cases now.
Thinking it could possibly be a dirty solenoid from or weak coil packs from a test I used from
( pulling plug out slowly while engine is running ) 2 out of the 4 showed no change at all.
The car is due for a new battery and oil change.
Trying to figure out if I should just call this one a wrap or if I'm close to finding the fix
Would love some insight!
Old Feb 3, 2021
Re: Engine loses power at 2600-3000 rpm especially going up hills P1861
remove plugs and check the color. If coils not working, color should show it
https://www.google.com/search?q=plug...jphSe3oqHnO5uM
Old Feb 3, 2021
Katalyst's Avatar
The spark plugs didn't seem to have much different of a color when we pulled them to check. Maybe a little black
Old Feb 3, 2021
Colin42's Avatar
Cat plugged?
Old Feb 3, 2021
Katalyst's Avatar
I initially thought this, is there a way of telling?
Old Feb 3, 2021
Katalyst's Avatar
Originally Posted by Colin42
Cat plugged?
How can you tell if the cat is plugged? This was on my list of culprits initially. There's 2 Cats one closer to the engine then another one shortly after. Which would most likely get plugged?
Old Feb 3, 2021
Katalyst's Avatar
I'll give it another look and get back to you
Old Feb 3, 2021
Colin42's Avatar
Loosen the exhaust flange before the cat and see if acceleration improves
Old Feb 3, 2021
Katalyst's Avatar
I'll do this and tell you the results!
Old Feb 25, 2021
Katalyst's Avatar
I loosened the o2 sensor on the 1st cat and this seems to have solved the issue. Should I hollow out the first or second cat?
Old Feb 25, 2021
Katalyst's Avatar
[Update] Engine loses power at 2600-3000 rpm especially going up hills
I completely removed the O2 sensor on the 1st cat and the loss of power at 2500 RPM is no longer happening. This is leading me to believe that one of the cats are plugged.
Any ideas on which cat would most likely be plugged?
Should I try to use a cat-con cleaner? Should I remove the cat and soak in a degreaser?
Most likely going to try disconnecting the exhaust between the 1st and 2nd cat to break up and remove the clog. If that proves too difficult I might resort to drilling the cats to break them up.
Any recommendations would be greatly appreciated
--- Original Post ---
Code P1861
Old Feb 25, 2021
Colin42's Avatar
You replace the cats, otherwise Captain Planet gets angry
Old Feb 25, 2021
Katalyst's Avatar
If Captain Planet has an extra $700 I would be more than willing haha
I feel bad about it but at least the car has a tiny engine/ hybrid
All jokes aside you have any tips?
Old Feb 25, 2021
Colin42's Avatar
I would assume that the primary cat would clog first, check with an exhaust shop, might be able to weld in a new cat cheaper
Old Feb 25, 2021
put o2 sensor back, remove cat 2 (will sound like a truck, but should answer the question 1 or 2. (If both are bad, you are going to have to change both)
Old Feb 25, 2021
if you decide to hollow, do the 2nd. 1st one could trigger the o2 sensors
Have at least one cat working. Do you have smog tests where you live?
Old Feb 25, 2021
Katalyst's Avatar
Sounds good, I will do the second one first.
Will it damage the engine if I end up having to clear out both and drive it around?
I don't have an issue if there's a constant engine light from the o2 sensor
I live in a rural area so there's no smog tests
Old Feb 25, 2021
having the light on means you will not know when another problem comes up
Cheaper comes expensive later on
Old Feb 25, 2021
Katalyst's Avatar
Good point. I only need this car to last me 6 more months and it has such high mileage that I just need it to work temporarily until I can afford a new car.
Old Feb 25, 2021
Colin42's Avatar
Just make it a habit to scan the car every week/month
Old Feb 25, 2021
Katalyst's Avatar
Thanks everyone! I will update when I've made more progress in the next couple days. Should be warm enough to get it done!
Old Feb 26, 2021
BrotatoChip's Avatar
Super Moderator
Removing one or both cats will likely make the exhaust tone change as well. May be louder and sound more raspy.
Old Feb 26, 2021
PS:
There is a reason cat are being stolen from cars...[no, I don't condone this practice]
If you sell to a recycler, you could maybe partially pay to weld pipes in its place (2nd cat is the one that you can do this easily, the 1st have the sensors) - [no, I don't condone doing this either - but considering COVID situation...]
Old Feb 26, 2021
Colin42's Avatar
Yeah with it being a hybrid, you should get pretty decent money for the cats rather than zero for hollowing then out
Matthew Alder
Apr 21, 2016 09:21 PM
dHordejuk
Jun 12, 2014 02:53 PM
Lord Omega
Mar 5, 2011 12:38 AM
dkablack
Buy, Sell, & Trade - Archive
27
May 27, 2010 10:59 AM
BmoreAMan
May 19, 2010 11:51 AM
