RPM surge
Old Feb 10, 2021
qazz96's Avatar
qazz96 is an unknown quantity at this point
RPM surge
hello guys ive searched around on this topic for a bit before posting.
Recently cleaned the throttle body, yes i opened it using the throttle and cleaned it didnt push the flaps by hand and stuff. but now when am in neutral the rpm surge between 2k all the way upto 3k and come down and then go up again and keeps doing it untill the car fully stops WHEN IN NEUTRAL AND COASTING
and it idles around 900-1k but before the cleaning it used to idle perfeclty.
another thing when going to change gears the car revs up for some reason now? and when i let go of the throttle in gear it takes a second and then i feel like the throttle is let go.
No codes only codes i have are for an O2 sensor and evap code
what should i check for next? new throttle body? MAP sensor? MAF sensor? am all out of ideas
Old Feb 11, 2021
qazz96's Avatar
Re: RPM surge
anyone at all? smh
Old Feb 12, 2021
BrotatoChip's Avatar
Super Moderator
Re: RPM surge
What did you clean it with?
Did you take off a vacuum hose and forget to put it back on? Vacuum leaks can cause high idle.
Old Feb 17, 2021
qazz96's Avatar
Re: RPM surge
cleaned it with a throttle body cleaner, didnt take anything off at all just took the body off the intake and cleaned it, noticed the gasket was a bit dirty so i just got a thermal gasket on it and now when i brake the rpm bounce up and down when iam stopped like they are surging i honestly have no idea what could be it , i havent drove it yet after putting in the new thermal gasket cause roads are not it right now but ill report later if driving it after fixed anything.
Old Feb 17, 2021
Neme Sis Yaj's Avatar
Neme Sis Yaj is an unknown quantity at this point
Re: RPM surge
mite be ur TPS check that cuz I once had a problem with the rpm going up and down. after changing the TPS problem solved.
Old Feb 17, 2021
qazz96's Avatar
Re: RPM surge
can u get that as a separate part? or would i have to replace the throttle body with a used one?
Old Feb 18, 2021
Re: RPM surge
u can buy it separately and then search on YouTube on how to put it on. thats what I did.
Old Feb 18, 2021
Super Moderator
Re: RPM surge
If you have a scanner that will show live data you can see if the TPS is reading correctly. I would expect a fault if it were not though.
Recheck your work again. Verify you got everything hooked back up properly. A vacuum leak anywhere can cause high idle.
Old Feb 26, 2021
qazz96's Avatar
Re: RPM surge
checked live data TPS seems fine, blips go up to 17% and then back to idle at 14.1%, honestly if i cant figure it out ill just live with it but i dont like the engine reving like that for no reason.
timdoco4
Dec 17, 2019 08:36 PM
Robfather
Jun 12, 2018 05:43 PM
bluetool11
Mar 19, 2015 07:55 PM
whittam
Mar 28, 2014 11:50 AM
JohnHenry
Oct 26, 2011 07:49 PM
