Take to long to reach normal idle during cold start.
Old Mar 3, 2021
Bongzky's Avatar
Bongzky is an unknown quantity at this point
Hi guys, i got a LXI 2008,and i got a problem during cold start. When i start my car in morning, i know that the idle is higher than normal. It ramps up to 1300-1500rpm then slowly it will go down. My problem is it takes a while to reach 750-800rpm. It takes 8-10 minutes to reach the 750rpm. Is this normal? I got my throttle body cleaned, reset and relearned, new sparkplugs, cleaned my MAF sensor, changed engine oil and atf. But the problem is still there. I would appreciate guys if you could help me with this one. Thanks in advance.
Old Mar 3, 2021
BrotatoChip's Avatar
Super Moderator
Re: Take to long to reach normal idle during cold start.
Sounds normal to me.
Old Mar 3, 2021
Bongzky's Avatar
Is this normal? I ask some of my friends who has the same car, they told me its too long to reach that normal idle. It should be less than 5 minutes.
Old Mar 3, 2021
thermostat stuck open?
temp gauge screwed? (use obdII reader)
temp sensor itself screwed?
Old Mar 3, 2021
Colin42's Avatar
Depending on how cold/windy it is that can be perfectly normal
Old Mar 3, 2021
FRSam's Avatar
Click Here
This is just at idle? You’re not driving at all through this? That’s perfectly normal.
Thaik
Jan 21, 2013 11:48 PM
vic22
Mar 21, 2012 01:10 PM
wikkaco0
Apr 6, 2008 08:53 PM
speedracersong
Jan 21, 2006 09:27 PM
ponyman
May 24, 2004 05:44 PM
