Do I Need to Replace Bad Engine Mount?
Old Jul 5, 2022
stonedrives's Avatar
stonedrives is an unknown quantity at this point
Recently, it has come to my attention that I may have a bad engine mount. After my 09 Civic has been running for about 30 minutes, it begins to vibrate at ideal. However, it does not vibrate when I first start the car or just doing occasional (local) trips. Not sure if I should still invest the money right now or not. Is it needed to replace these?
Old Jul 5, 2022
Re: Do I Need to Replace Bad Engine Mount?
not an immediate catastrophic failure.
but do plan to have it solved
vibrations might start making stuff loose, might break the remaining mounts.
Replace before you end up with only one mount... mechanics will also check if remaining mounts are good or not
cruzfactor
Apr 2, 2018 09:20 AM
shaan
Mar 31, 2015 12:05 PM
Per32
Sep 1, 2012 05:33 PM
ZSKCivic01
Jan 30, 2006 03:58 PM
EM2Civic
Dec 3, 2004 03:55 PM
