Idle problem
Old Apr 14, 2020
Zeyad's Avatar
Zeyad is an unknown quantity at this point
Idle problem
Hello again.. May ALLAH protects you from corona virus... My 2007 civic do not idling.. After releasing padal.. Rpm come and go between 300 to 500 for a minute and ingine stop.. I had two codes 0135 and 1658 but these codes are like 5 month old and no new codes after this problem.. Any help please.. And excuse my English.. It my second language
Old Apr 14, 2020
mac25's Avatar
Dr Krieger of Modification
Re: Idle problem
May Allah, be with you to, brother. 😁
I'd start by replacing the Air fuel sensor, as it has the bad heator.
With no set heator circuit, wideband A/F sensors, wont ne accurate. This will effect the stft and ltft, maps; causing the vehicle to not run properly.
after that, reset to ecu, and see if the other code corrects itself. If not, check that circuit.
Old Apr 15, 2020
Zeyad's Avatar
Re: Idle problem
Thnx folks.. I found that the intake hose behind ingine was cut.. because of steering rack fixing.. they accidentally cut the hose
Old Apr 15, 2020
Colin42's Avatar
Re: Idle problem
Try taping it up as a temporary fix to see if it fixes the problem
Old Apr 15, 2020
Zeyad's Avatar
Re: Idle problem
Yes this fix the problem.. Thnx
Old Apr 16, 2020
Colin42's Avatar
Re: Idle problem
Good to hear, that's probably a dealer only part, you can probably find one at a junkyard for cheap
BigYeti
Nov 24, 2017 08:15 AM
Lucille92
May 26, 2014 09:33 PM
stHcivic02
Apr 1, 2014 02:54 PM
frmg0014
Jun 3, 2012 12:04 AM
cgrimond
Oct 11, 2011 02:17 PM
