2007 honda civic wont rev past 3500 rpm
Old May 26, 2021
jc23455's Avatar
jc23455 is an unknown quantity at this point
my car started to bug a little back so i decided to check what was wrong, and so i changed my air filter. then i thought it was maf sensor so i bought a new one changed it. same problem. then i decided to give a throttle body a good clean. still didnt solve the problem. then one of my freinds siad to check my spark plugs, and they were shocked so i changed and still didnt fix my problem. i plugged the machine and the codes that its throwing at me are p0113 and p0102. do you guys think that the maf sensor is faulty or its something comepelty different.
Old May 26, 2021
mac25's Avatar
Dr Krieger of Modification
Re: 2007 honda civic wont rev past 3500 rpm
Might be the
-IAT sensor
-MAF
but you should also check the basics first
-grounds
-battery terminals
-fuses
-relays
if all related fuses and grounds check out, it's also good to check the wiring to the sensors, as a rat could have chewed one. There are wiring testing procedures on youtube.
Old May 26, 2021
or an extremely dirty air filter clogging the air flow
Old May 27, 2021
jc23455's Avatar
i changed the fuses and checked my grounds. im a look up some wiring testing techinques and ill let you guys know.
Dustin19902
Aug 10, 2014 08:00 PM
phaze3k
Oct 8, 2012 10:29 PM
RemyL31
Mar 24, 2011 07:09 PM
David923
47
Aug 30, 2010 02:35 PM
Boods
Sep 29, 2006 06:02 PM
