Crazy Rev Limiter??
Old May 19, 2012
phaze3k's Avatar
phaze3k is an unknown quantity at this point
Unhappy Crazy Rev Limiter??
Help Somebody!!! I have a 2001 honda civic..the other day when i was driving to work my aftermarket intake came a lose and now my car runs crazy. i reset the computer but still the same problem. when the rpms reach about 4000-4500 the car revs up and down, just like it has a rev limiter on it.. it wont go past 5000 rpm at all. plus its idling wierd and the tranny i shifting wierd did a ..sensor go bad?? the egr valve is what it acts like...
Old May 19, 2012
Re: Crazy Rev Limiter??
stop in any autozone or similar and have the engine codes read.
Old Jun 7, 2012
sjryser's Avatar
sjryser is an unknown quantity at this point
I have a stock 02 civic ex coupe and have similar probl with rev limiter feeling at 5k...none of the other problems though...?
Old Jun 7, 2012
MR W's Avatar
MR W is an unknown quantity at this point
Lightbulb Re: Crazy Rev Limiter??
May check into your car TPS or Map sensor may lose or broken to cost the problem since you had after market intake come lose...
Old Jun 7, 2012
04 Honda Civic's Avatar
Need to get a quality intake. (Or at least quality clamps)
Pull the code.
Your car is in limp mode.
Old Oct 8, 2012
y8_minime's Avatar
y8_minime is an unknown quantity at this point
It sounds like your car is in limp mode, it has to do with timing, go to your ignition coil under the hood and make sure it is plugged in correctly
Edit: your intake coming loose may have knocked it off
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
carid
Sep 28, 2015 10:13 AM
99BoostedSi
Sep 7, 2015 04:49 PM
