2012 Civic LX Automatic Noise
Old Jan 22, 2021
hp500880's Avatar
hp500880 is an unknown quantity at this point
I need help with a noise my car is making. This noise happens after a cold start on cold days. The sound does not occur until the car is in gear. It is louder in reverse than in drive. In the video the car is in reverse with the brakes on. The noise goes away after driving for 5 minutes or so. Any help is appreciated.
Old Jan 22, 2021
Re: 2012 Civic LX Automatic Noise
check engine mounts, trans mounts.
Old Jan 22, 2021
hp500880's Avatar
I was looking at them today and visually I can't really see a problem. Tomorrow I am going to have someone else cycle the car through drive and reverse while I look and listen. I suppose if they move a lot that suggests they're bad. Hopefully I can pinpoint where the noise is coming from.
Old Jan 23, 2021
hp500880's Avatar
The engine moves a bit when shifting between drive and reverse but it doesn't seem like an abnormal amount. The noise sounds loudest at the left side of the engine. I put my hand on the passenger side motor mount and the vibration feels much less on the mount than on the engine itself. The mount vibrates only very slightly. The vibration is dampened by the mount. Could it be a pulley bearing? See the new video for noise in the engine compartment.
Old Jan 23, 2021
use something to hold the exhaust heat shield
Old Jan 23, 2021
Colin42's Avatar
Didn't these have the issue with the collapsing driver's side mount?
Old Jan 23, 2021
ah, yeah.
the mounts are visually inspected.
Old Jan 24, 2021
hp500880's Avatar
I thought it might be the serpentine belt tensioner so I de-tensioned that and spun all the pulleys by hand. All of them felt normal. After pumping the tensioner several times to de-tension it and feel around the sound has disappeared. I think it could be that the tensioner is going. If the sound re-appears I will replace the tensioner.
Old Jan 24, 2021
hp500880's Avatar
This person has the same issue. The sound is the same. His comes in and out. Mine was continuous.
Old Jan 24, 2021
I thought i heard a thud in the video, that's why i said mounts?
i might be hearing things
Old Jan 24, 2021
hp500880's Avatar
Thanks for your input
Old Feb 5, 2021
hp500880's Avatar
To add a conclusion to this thread: The sound came back as expected so I replaced the belt tensioner and the belt and the noise and vibration are totally gone.
Old Feb 5, 2021
Colin42's Avatar
Thank you for following up 👍
flipcrip
Transmission
Jul 8, 2021 09:38 PM
Carcar0220
Jan 19, 2016 06:36 PM
tommycanada
Sep 5, 2015 04:59 PM
bsrush16
Dec 29, 2012 05:15 PM
edgecliff
Wheels and Tires
Nov 1, 2010 06:40 AM
