Temp sensor question
Old May 1, 2021
Cmstackx's Avatar
Stack
Cmstackx is an unknown quantity at this point
I ordered 1 temperature sensor from RockAuto and it came with a metal Oring not a rubber one. Is this incorrect or is it for the lower temp sensor? I believe the top one has a rubber oring but I could see the radiator one having a metal oring. Any idea?
Old May 3, 2021
BrotatoChip's Avatar
Super Moderator
Re: Temp sensor question
Do you realize how little information you've given us?
Old May 3, 2021
Cmstackx's Avatar
Stack
I’m not sure what more information you need. Are the temp sensors (ECT) supposed to come with a rubber oring or a metal oring. The upper and lower are the same part, they do the same thing. Are they both supposed to seal with a rubber oring or do they each seal differently. I ordered a non-OEM temp sensor because I broke the plastic surround, the one that came has a metal oring or crush washer. Is this proper, I’m unfamiliar with this particular vehicle and was wondering if anyone else has received a temp sensor with a crush washer rather than a rubber oring..
Old May 3, 2021
what year/trim level?
Old May 3, 2021
Cmstackx's Avatar
Stack
2007 civic lx coupe manual
Old May 4, 2021
I would just contact rockauto, I hear their customer service is good
Old May 4, 2021
Cmstackx's Avatar
Stack
I did, they told me the metal washer was right for the application but I don’t believe it is. They wouldn’t supply a rubber oring because they said the metal washer was what is correct.. though they sell them with the rubber oring as well.. I should have just bought that one
Old May 4, 2021
FRSam's Avatar
Click Here
You could just return it. They’re pretty good with exchanges
Old May 4, 2021
Cmstackx's Avatar
Stack
I’m just going to try to match the oring and keep the temp sensor
Old May 4, 2021
FRSam's Avatar
Click Here
Actually, while I’m thinking about it, what brand sensor is it?
Old May 4, 2021
Cmstackx's Avatar
Stack
I bought a non-OEM, cheapy.. Ultra-Power was the brand.
Old May 4, 2021
Super Moderator
It was designed for a metal washer, I would use it. If it leaks return the sensor to Rockauto as defective (for free, shipping included). They may also just let you keep it because it's so cheap.
Old May 4, 2021
FRSam's Avatar
Click Here
Don’t be surprised if the sensor doesn’t work either; Honda’s don’t take well to aftermarket sensors
Old May 4, 2021
Cmstackx's Avatar
Stack
I think I’m just going to take the hit for the 3 dollar sensor and just purchase the right one with the rubber oring.. it’s honestly to much trouble to return it for 3dollars. And while I don’t believe it was specifically manufactured to take a metal washer in this application rather than an oring because it is designed to replace a part with the exact same part number that has a rubber oring, I’m not going to use it because BrotatoChip said it should be used with the metal washer because it was manufactured to use the metal washer. I just added it on to the order cause it was 3 bucks and I thought I would replace it since I already did the top one.. I haven’t found anywhere that it says to use one with a metal washer all service bulletins and DIYs I’ve come across show a sensor with a rubber oring so I’m just gonna get the one with the rubber oring.. thanks for your time
Dankers92
Jan 16, 2019 09:18 AM
arizaga8799
Oct 2, 2012 11:19 PM
wpaxt
Aug 14, 2011 12:24 AM
Zigen1
Oct 11, 2003 03:52 AM
MyCivic
Mar 31, 2002 05:35 PM
