Oxygen sensor????
Old Mar 31, 2002
MyCivic's Avatar
MyCivic is an unknown quantity at this point
Oxygen sensor????
What sensor is located on the intake? Because I took it out to put my Nitrous jet in the hole which was provided for the sensor. The jet needs to be 6 in away fromthe throttle body and after the sensor. But the cables on the sensor are so short that I am no able to replace the sensor on a different spot on the intake. - yes eventualy i will make cables longer - but till then I am driving with the sensor pulled out, and strangly enough i do not have any problems. What does the sensor do? does it need to be there??
Old Mar 31, 2002
leadfoot78's Avatar
leadfoot78 is an unknown quantity at this point
Its not an oxygen sensor. I think its a intake pressure sensor or maybe a temp sensor. And with out it you are probably getting a little worse mileage
Old Mar 31, 2002
MyCivic's Avatar
Hmmm??? So i could drive with out it??
Old Mar 31, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
It's an air temp sensor. I'm surprised your "check engine" light isn't on.
Old Mar 31, 2002
WhopSi's Avatar
WhopSi is an unknown quantity at this point
it is a tempurature sensor. I saw a whole diagram, and step by step procedure in Honda Tunning Magazine when they were installing an NX system on a 2k1, but I'm not sure if it is necessary
Old Mar 31, 2002
MyCivic's Avatar
probably it determines the density of air and what ratio of fuel should be added for the correct mixture, all this stuff with colder the air more oxygen particles. Hmmm it this case I better lenghten the cords and plce it before the jets, thx for help [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Beer frr everyone [IMG]i/expressions/beer_yum.gif[/IMG]
BootyDo
Jun 21, 2016 03:45 PM
carid
Nov 7, 2015 01:46 AM
Green02civic
Jul 27, 2015 10:48 PM
mistermenphis22
Jul 13, 2015 04:43 PM
CivicsClass101
Jul 9, 2015 11:14 AM
