civic fn1 i-vtec spool valve solenoid - manual test check help?
Old May 22, 2021
xlr8rhot's Avatar
xlr8rhot is an unknown quantity at this point
hey guys.
I'm not exactly 100% sure if my FN1 Civic (2010) is operating on the VTEC correctly... as car feels a little sluggish throughout revs .
I checked the spool valve solenoid for continuity using a meter and its also reading 16 Ohms resistance, both these tests were good results.
However, i tried the manual "click" test by placing a wire from + on the battery, to the + terminal on the solenoid (as if to activate it) but nothing happened.
Perhaps i should have grounded the other solenoid terminal first ? I didn't try this in case i blew something up lol....
I should mention that there are no engine management lights on, but a light did briefly come on once or twice in the past year, but never since....
please advise
thanks
Old May 22, 2021
Re: civic fn1 i-vtec spool valve solenoid - manual test check help?
what regular maintenance have you done?
Old May 24, 2021
xlr8rhot's Avatar
nothing as yet, only got the car just before lockdown. it was regularly serviced. Since lockdown I have done nothing as i only did about a 1000 miles (in a year).
oil is clean and i only put a k&n air filter in to replace the original.
I have bought a gasket / filter for the solenoid and will take it off next weekend to see if ihas any internal issues. Just wanted to know if it can be "click-tested" in-situ, before doing that.
Maybe im just expecting too much from this car since i sold my 2.0L Turbo (chipped and tuned) Laguna ?
Old May 24, 2021
BrotatoChip's Avatar
Super Moderator
Yes, the solenoid needs power and ground in order to work.
jdfrock2003
18
Nov 1, 2023 09:00 AM
9812Valve
Transmission
15
Jun 14, 2021 02:24 PM
Ghack
Nov 14, 2018 09:13 AM
timbolio
Nov 4, 2018 03:39 PM
BBrosario
Jun 30, 2016 08:47 PM
