2007 Civic SI ticking noise
Old Mar 10, 2020
MikeyDude's Avatar
MikeyDude is an unknown quantity at this point
I have a 2007 Civic SI with 145k miles. (K20Z3) I noticed this ticking noise after the first time I adjusted the valves on it. So of course I figured it was the valves, but now they've been adjusted like 4 times by me and been taken to a shop to do the vavles and timing chain. Yet the noise is still there! Im not sure if this is normal or natural. I never ever noticed it when I first got the car and I'm usually very sensitive to engine noises so I don't know! Maybe I broke something somehow when first doing the valves or what? Only think I can think of is either the valves or I know I replaced the PCV valve around the same time could it be that? I know people say the K20s are loud and have loud injectors and I have used injector cleaners so maybe that made the injectors louder? I feel like I would've noticed this noise before or something, but its possible I suppose. So is this noise normal or natural? I feel uncomfortable with how loud it is, although I'm quite certain its nothing catastrophic. The car is stock other then a K&N Cold air intakeFYI. I only hear the noise below 2k rpm and its mainly noticeable from outside the car or when the windows are down. She drive great otherwise! So let me know what you guys think.
Old Mar 11, 2020
mac25's Avatar
Dr Krieger of Modification
Re: 2007 Civic SI ticking noise
If the noise goes away when hot it's an exhaust leak.
Old Mar 11, 2020
MikeyDude's Avatar
I actually mainly hear it when the car is warm. It seems to not be there as much when the cars cold
Old Mar 11, 2020
FRSam's Avatar
Click Here
Have you checked your exhaust manifold? If the bolts back off a bit and there痴 an open gap, it値l make a tapping noise.
Please note that I知 currently at school with no wifi so I haven稚 seen the videos yet.
Old Mar 11, 2020
MikeyDude's Avatar
Originally Posted by Chezboat24
Have you checked your exhaust manifold? If the bolts back off a bit and there an open gap, it値l make a tapping noise.
haven稚 really checked any exhaust stuff, so I will. I know I looked under the car once with it running didn稚 see anything obviously weird with the exhaust system. But who knows! I値l check it out
Old Mar 11, 2020
FRSam's Avatar
Click Here
Certainly wouldn稚 hurt to check.
Just to clear up any possible confusion, the manifold that I知 referring to is the one that bolts straight up to the engine, so you won稚 see it under the car. It痴 also referred to as the headers. You won稚 notice it with the naked eye (unless it痴 cracked), so you値l either need to try to bolt it back down or remove and inspect it.
Old Mar 11, 2020
MikeyDude's Avatar
yea I totally get it! I didnt see any missing bolts or loose bolts and no cracks or anything like that no air or carbon marks showing anything obvious. I値l have to check if there痴 any loose stuff or anything weird like you mentioned tho. It doesn稚 sound like exhaust to me but definitely possible.
Old Mar 11, 2020
FRSam's Avatar
Click Here
Just listened to the video, and to me it sounds exactly like valve lash.
I値l trust that the valve adjustment was done correctly. Low oil would cause that too, but I doubt that would be it. This screams exhaust leak to me, but I知 probably wrong. It痴 possible that the header bolts snapped. I知 not sure how common an issue that is on these civics, but I had it happen on my Supra and it tapped like hell.
Old Mar 12, 2020
MikeyDude's Avatar
I知 pretty sure your civic will have hydraulic lifters, but this is exactly the noise I知 hearing.
yea I hope the valves were done correctly as well, but maybe not! I値l check the headers for sure it痴 definitely a weird noise.
Bilal Ather
Transmission
Oct 22, 2015 07:04 PM
nsrhonda89
Jan 1, 2014 06:06 PM
bsrush16
Dec 29, 2012 05:15 PM
mkokotovich
Aug 26, 2011 07:16 PM
LikeWEEEEEEEEEE
Sep 17, 2002 08:06 PM
