Crankshaft seal removal
Old Nov 14, 2021
Avejoe1977's Avatar
Avejoe1977 is an unknown quantity at this point
Attempting to fix some leaks in my wife's 8th gen 2013 Honda civic lx 1.8l
Couple questions.
​​​​​​1. Anyone have any tips for a stubborn crankshaft seal?
I've torn at it a couple times out of frustration when the removal tool I got at HF didn't work. She's really stuck in there. Any sprays recommended or rewetting it with oil?
2. When trying to remove it I apparently caught a little spring that was behind it. Didn't see it listed in any videos or forums I'd gone through before attempting to remove the seal.
Any know what the spring is called so I can get a replacement once I actually get the seal off?
Old Nov 15, 2021
Re: Crankshaft seal removal
some seals have a spring inside
Old Nov 15, 2021
Colin42's Avatar
Yeah that's part of the seal, use small picks and be careful
Old Nov 16, 2021
Avejoe1977's Avatar
So this is where it stands at the moment.
including some photos.
Pretty torn up. Tried the hook on a handle that I saw guys use on YouTube to remove the seal and had no luck.
The picked up and tried the one with the screw in the center but can get a hold of the seal now.
Any thoughts?
I'm assuming the metal ring behind the seal is not part of a seal and should not be damaged?
Any advice?
Old Nov 16, 2021
BrotatoChip's Avatar
Super Moderator
The last time I removed a crank seal I used a pick with a hook. I think I also used a small flat head screwdriver to pry it out. You just don't want to scratch the part on the crank where the seal touches, same with the block side where the seal sits.
Old Nov 16, 2021
Last time I did a crank seal, I carefully drove a self tapping screw into the seal and carefully yanked it out with pliers.
Old Nov 16, 2021
yeah, that looks like a spring inside a seal - when you get a new one, you will find it there.
the seal have been there for 8 years, it likes its house :P
They are painful to pull out because they are designed to not get out, sorry...
Old Nov 16, 2021
Avejoe1977's Avatar
So the seal has a little metal ring that it's sitting on.
Is that part of the seal or is that what the seal is resting on to hold it in place?
Old Nov 16, 2021
the seal is one piece comprised of the metal ring with the rubber coating and the spring inside
get a new one and you will know what we mean.
Old Nov 17, 2021
Super Moderator
Metal ring helps the seal hold shape when pressed in.
Old Nov 17, 2021
Avejoe1977's Avatar
Gotcha, so I can pry against it and not just the rubber of the seal.
Was afraid it might be part of the casing or something and didn't want to press on it
Old Nov 17, 2021
https://www.victorreinz.com/en/servi...on.aspx?region
Old Nov 17, 2021
Super Moderator
Good pics there.
Yes you can pry against it. Again, just don't gouge the surface it seals to on the engine or it will leak.
Old Nov 26, 2021
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
This is probably the best method to pull out the seal if conventional methods aren't working.
dnmacdon
Aug 30, 2016 10:05 PM
Dakota21601
Aug 18, 2015 08:41 PM
Rem7mmMag
Dec 11, 2012 02:42 PM
soarintothesun
Jun 5, 2008 11:19 AM
valenzuela
Apr 18, 2007 11:19 PM
