Car buzzing upon start and gas pedal pressed
Old Apr 1, 2021
jetski76's Avatar
jetski76 is an unknown quantity at this point
Hello,
I have a 2013 Honda Civic with 80K miles on it. For the last few weeks, the dashboard and the cup holders next to the driver's seat would buzz as if music is playing and the bass is turned on to the max upon start in the morning. The buzz would come and go when I was riding the car.. The ride was sorta bumpy as if the shocks/struts needed replacement. Took it to shop yesterday. They said the engine mount is broken and replaced it. When I picked up the car today and started the car in the shop, the car buzzed even louder and when I pressed the gas, its as if I need to apply extra force to overcome the buzz. Once the speed is more than 40, the buzz goes away and comes back up when the car is at standstill. When I asked the mechanic about it, he asked me to drive it a few days and come back the the issue persists. Had him for 11 years, I trust him.
Questions:
1) Is this an issue with the engine or something else?
2) How common is it to have this issue with a new engine mount?
2) Is this safe to drive for a few days?
Thank you
Old Apr 1, 2021
Colin42's Avatar
Re: Car buzzing upon start and gas pedal pressed
I'm going to guess cheap aftermarket mount. Ok to drive.
Old Apr 1, 2021
jetski76's Avatar
Thank you for the reply. The mount cost $170 and the labor was $89. Is that the cheap version?
Will the buzzing noises ever go away?
Old Apr 1, 2021
your mechanic can tell you better than us, he can see your car...
Old Apr 1, 2021
Colin42's Avatar
Not really, you can add foam tape to whichever areas are contacting to eliminate/reduce the noise
Old Apr 1, 2021
jetski76's Avatar
I see. Will replacing the current engine mount ($170) with a OEM mount eliminate the vibrating noise?
Old Apr 1, 2021
Colin42's Avatar
Most likely, which mount was it?
Old Apr 2, 2021
jetski76's Avatar
I went to the shop today and had a drive with the mechanic with put the mount. He said the make of the mount was Honda and that he has put the mount slightly higher (supposedly the proper position according to him) and expects the vibrations to go away in 3-4 days as the engine moves to adjust. If not, he will have to move one of the other four mounts. They do mounts for Honda all the time and this is typical in the first week or so. The vibrations are less today, although very much there when you idle start or when you accelerate 0-40. I will see for the next 4 days and see how it goes. If you have any comments, please let me know.
Old Apr 3, 2021
Colin42's Avatar
That sounds fishy to me
Old Apr 3, 2021
jetski76's Avatar
Thank you. I will call them in a few days if things do not improve.
Mazinh
Oct 20, 2020 01:02 AM
livin1985
Transmission
May 21, 2019 02:55 PM
Masker
Mar 15, 2018 11:35 PM
shafaqat309
Jun 10, 2016 08:58 PM
jlauu
Dec 29, 2004 02:28 PM
