2007 Honda Civic Stalling and black smoke
Old Mar 23, 2022
dejideoye's Avatar
dejideoye is an unknown quantity at this point
I have a 2007 Honda Civic with approximately 110,00 miles on the clock.
Recently, after driving for a while and the engine is warm, it would lose power, start blowing black smoke and eventually stall. It starts right up again immediately, but it doesn't move, it starts idling roughly and blowing out black smoke. This only happens when the engine is very warm, after driving about 15-20miles.
CEL is off, and it throws no codes.
I have replaced the injectors, ignition coils, coolant engine temperature sensor, spark plugs, throttle body and the ECU and I have checked for vacuum leaks and found none. Any ideas please
Old Mar 23, 2022
BrotatoChip's Avatar
Super Moderator
Re: 2007 Honda Civic Stalling and black smoke
I think running stupid rich can cause black smoke and stalling issues. If you have a code reader that will show live data you can look at the long/short trim values to determine if extra fuel is being added.
Old Mar 23, 2022
Colin42's Avatar
Unplug the primary o2 sensor and see what it does
Old Mar 23, 2022
dejideoye's Avatar
Done that too, still the same. Whenever I unplug any part, it immediately throws the code for that part, but when I plug it back in and clear code, it never comes back despite the car running like crap
Old Mar 23, 2022
dejideoye's Avatar
I will see about this, but even without plugging in a tool, it's obvious that it's adding extra fuel, to identify the reason for that is now the problem as no codes are shown, which has prompted me to replace every replaceable part, even the ECU
Old Mar 23, 2022
Colin42's Avatar
I know it's going to throw the code, does it still stall and spew black smoke?
Old Mar 23, 2022
dejideoye's Avatar
Yes, it still does
Manasmakkar
16
Jan 31, 2020 08:22 AM
azi90
Rear Control arms, rear tire wear early models
Nov 28, 2019 11:04 AM
gsb104
Dec 11, 2015 01:07 AM
CiViCPrAnInG2k1
Apr 15, 2006 06:14 AM
