2006 civic ex 1.8 AT crank no start
Old Nov 26, 2022
Jackkrippter's Avatar
Jackkrippter is an unknown quantity at this point
Replace upper and lower O2 sensor
replaced all coil packs
replaced and gapped spark plugs
replaced fuel pump relay
replaced fuel pump
sprayed starting fluid. Into intake sputters slightly.
new radiator
after I installed gapped spark plugs car did not fire up again. No engine code light.
cranks no fire. Followed all the advice I could find.
Old Nov 26, 2022
Colin42's Avatar
Re: 2006 civic ex 1.8 AT crank no start
What brand were the parts? Why did you change all of these parts?
Old Nov 27, 2022
car basically started falling apart
code reader for oxygen sensors
code reader for maf sensor
code reader misfire for coil packs and plugs
crank no start symptom
then replaced fuel pump and relay
pump has power
still crank no start
Old Nov 27, 2022
Colin42's Avatar
Still need to answer the first question
Old Nov 27, 2022
Oreilly parts
let me clarify, car ran perfect with new parts minus fuel pump. Turned it on. Rpm was great and steady. Shut it off then would not start again only crank
Old Nov 27, 2022
Colin42's Avatar
These cars don't like aftermarket electronics.
DIYfan
Apr 12, 2022 08:06 AM
LS2729
Engine start problems
18
Aug 15, 2021 03:31 AM
jearhart
Apr 15, 2018 10:56 AM
Kpike70
Nov 3, 2017 07:33 AM
civic_civilian
Dec 25, 2012 08:42 PM
