Vtec solenoid question
Old Mar 28, 2026
mcnamee05's Avatar
mcnamee05 is an unknown quantity at this point
Hi, I bought a 2008 Honda Civic LX manual transmission the other day for a work car. The previous owner said they had the motor replaced recently and I stupidly didn't ask many questions. On the drive home I got a check engine light, but it still seemed to drive fine. Once I got home, I plugged in a scan tool and got the code P2646. With a little googling I decided to remove the Vtec solenoid to replace the gasket. Once I removed the solenoid I realized there was no oil pressure sensor unlike all the videos I watched. there was just a bolt in that spot plugging the hole. I looked around and couldn't find any indication of a clip that would be plugged into that. Would that be the reason for my check engine light and any idea how I can replace it without having the wires to connect into it?
Auto parts store didn't have the new gasket, so I haven't put everything back together yet so no idea if the gasket fixed anything or not yet.
thanks in advance for any help I can get.
Old Apr 6, 2026
max_gh's Avatar
Tut masla dohuya (C) Mytets
max_gh is an unknown quantity at this point
Post Re: Vtec solenoid question
Hi, check and clean the plugs.
After plugs checking, see live data from v-tec oil pressure sensor by your scanner.
Clean all DTC, start your engine and driver over 3000rpm.
LionSpratt
Apr 26, 2015 01:02 PM
elementtw1023
Apr 18, 2014 08:04 PM
sweet_t883
Jan 22, 2014 11:23 AM
ricerrrr
Oct 13, 2012 12:40 AM
circuitt
18
Mar 28, 2012 06:10 PM
