2008 civic si goes into limp mode and bogs at 4000 rpm’s
Old Mar 23, 2023
masonmacisaac's Avatar
masonmacisaac is an unknown quantity at this point
Hello, I have been having this issue for a little bit of time. Checked my oil and it was almost bone dry after 3000 kms which i found very strange. Did a full oil change because there was no sense just topping it up and the problem still happened. So new oil was not the trick in this case. Got the code P2646 for my engine light if that helps anyone figure it out. It’s in honda right now because my harmonic balancer snapped along with the belt getting chewed up so I don’t have it right now but should by end of the week or early next week. Hoping to figure out how to fix the problem before then so I have an idea.
So just to clarify the car is a
2008 honda civic
si coupe
got 230,000 kms
I am in atlantic canada
Thank you.
Old Mar 23, 2023
BrotatoChip's Avatar
Super Moderator
Re: 2008 civic si goes into limp mode and bogs at 4000 rpm’s
First step in the troubleshooting, check oil level. Do you have an oil leak?
Troubleshooting can be viewed here: http://civic.hondafitjazz.com/A00/HT...646FAAT00.html
Old Mar 23, 2023
Yes as stated i noticed it was dry so i did a full oil change, haven’t had the car back since to check if it is still full because the belt blew.
Old Mar 23, 2023
Super Moderator
You can look at troubleshooting if you want to get a head start. Nothing we can really do until you've got the car back though.
If you lost that much oil over 3k km, there should be a very noticeable oil leak that needs addressed.
CurryBomb
Nov 21, 2015 07:35 PM
scoobydude911
28
Jan 1, 2012 02:58 PM
torres
Buy, Sell, & Trade - Archive
Sep 27, 2007 12:54 PM
