IAT sensor values
Old Feb 6, 2024
mattmaxon's Avatar
mattmaxon is an unknown quantity at this point
Question IAT sensor values
My son's 2010 Civic w/1.8L engine is getting a P0128
I used the Topdon Topscan to check the various values and we will replace the thermostat
I noticed the IAT value seemed way off at like 109° F sitting in the driveway engine off while the ambient temp was like 55° F.
Drove around a bit at highway speeds and it dropped a bit to 104° - 99° F with similar ambient temperatures
This seems way off
Does anyone have any data from another engine?
Matt
Old Feb 6, 2024
BrotatoChip's Avatar
Super Moderator
Re: IAT sensor values
Was that 109F after it had been running? Or was that after sitting overnight? If it's sunny and parked on pavement, under-hood temps could be quite a bit higher.
Old Feb 6, 2024
mattmaxon's Avatar
it's after a 35 min / 20 mile drive on the freeway (70-75 mph)
It was a cloudy day in the shade after sitting for about 10 minutes, as I stated we took it out and drove around at freeway speeds and the value only changed about 5° F from 109 to 104
Seems to me this would affect the emission control system calculations
Can you plug in a scan tool and see what values you get?
The research I've done so far indicate the value should be roughly 5° to 15° different
Last edited by mattmaxon; Feb 6, 2024 at 10:50 AM. Reason: corrected time and added distance for drive
Old Feb 7, 2024
Super Moderator
I don't own an 8th gen Civic, can't help you there. I can see what my CRV says if I remember later.
Let it sit overnight so you know it's completely cooled down. Then read IAT in the morning before starting the car. Should be very close to ambient temperature. 104°F IAT does seem a bit high for 55°F ambient temperature.
br94civic
Feb 22, 2022 11:46 PM
Dankers92
Jan 16, 2019 09:18 AM
pritz786
Jul 20, 2017 12:02 AM
leblanc
Oct 19, 2012 10:27 AM
adamzeppelin
May 13, 2006 02:43 PM
