Throttle Response is Sluggish
Old Jan 18, 2026
085spd's Avatar
085spd is an unknown quantity at this point
Purchased an 08 Civic 1.8L 5sp in Fall 2024 w/ 108K miles and currently 122K miles. Since purchased, at test drive, I noticed throttle response was poor and thought it just needed a set of plugs. According to previous owner paperwork, plugs had been replaced at 80K. At 110K replaced plugs and did not really improve throttle response. At 115K, MAF went out so replaced and throttle improved a bit but symptoms still present. I did some research and decided to replace EGR Valve, and throttle response improved, but symptoms persist.
I was getting on the freeway, pressed hard on the accelerator, and the engine instantly lost power and acceleration was sluggish.
Felt as if the timing had been retarded.
1. Hesitation/Sluggish Acceleration happen ONLY when Car has reached Operating Temperature
2. Between 2300 – 2700 RPMs
3. Goes Away after 3000 RPMs
4. Feels like a misfire but no Engine Codes
I change my oil every 2500 miles using 5-20w. Previous owner records show engine oil changes every 5K miles.
Anyone familiar with this problem?
Old Feb 11, 2026
bashhuey's Avatar
bashhuey
bashhuey is an unknown quantity at this point
Re: Throttle Response is Sluggish
I would definitely clean your throttle body it’s pretty easy to get to. Only when at operating temp is odd, it runs perfectly normal cold? o2 sensors could certainly be an issue as well. Also since that power loss getting on the freeway, were you able to continue driving afterward, does it still start and run?
ZweedNaat
Dec 23, 2017 11:49 PM
nohandbrake
Dec 6, 2017 08:59 PM
FrozenCaveman
Mar 11, 2014 02:21 PM
lgs 98dx
Feb 28, 2012 11:11 PM
teo829
Mar 18, 2010 11:32 AM
