PDA
View Full Version : 6th Generation Civic 1996 - 2000
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17
  1. JDM B18C into 98 EX
  2. ECU question
  3. Any other ideas on boggy engine?
  4. Damn it! Help?
  5. 97 Civic EX Sedan Build
  6. chains? snow tires?? help plz
  7. Because some car audio DIY's never work on the first try...
  8. Static Radio?
  9. Just Ordered New Tires/Rims! Woot!
  10. 98 swap
  11. Nitto Tire on Facebook, LIKE to win tires
  12. Oil Leak @ Oil pressure block
  13. F*** broken rear sway links
  14. Rim choices?
  15. block heater install
  16. Fuel Injector Cleaning
  17. headlight wiring (yeah, i know they're ricey!)
  18. Transmission won't engage....
  19. intermitten manual lock...
  20. New '00 coupe owner needs help
  21. 97 Civic EX with locking problems
  22. 2000 HX MT EGR Problems
  23. ys1 transmission problems... please help!!!!
  24. Can't Find New Trunk Lining, 00' EX
  25. speedo issues 98 dx
  26. First Post - need help with my dead '00 civic
  27. Just in time for winter!
  28. Help Needed with D16y7
  29. e85 in our cars
  30. 1997 Honda Civic DX d16y7 engine problems, pics inside.
  31. ek window problem
  32. Rough Idle and flashing check engine light on a 2000 Honda Civic EX. P0300 multiple m
  33. Cruise Control Adjustments
  34. Transmission vs RPM
  35. wiper sweep
  36. Brake Fluid
  37. Questions and suggestions D16Y8 full build 15-20 psi
  38. looking for a wiring harness and ecu!!!
  39. Starting Problems and High Idle 96 EX
  40. anyone from georgia
  41. WTF!? Window fell off rollers
  42. 1998 hx shakes @ 1500 rpm
  43. Timing quesions
  44. slips outof gear
  45. im about to have a 98 hb ek with a d15 vtec swap
  46. d16y7 problems.
  47. Fan only works on 2 settings
  48. new 6th gen coupe owner with questions...
  49. **1998 Honda Civic LX Sedan Build**
  50. Stage 2 or 3 cam for D16Y8
  51. P0505 CEL and 98 dx sat untouched for 1 year.
  52. Engine Swap y8 to z6 please help!
  53. Help with wiper issue!
  54. Missing spare tire srew lock
  55. Cylinder boring/head port and polish
  56. Dashboard/iPod Mount
  57. 10 second civic
  58. Sticky Throttle Cable
  59. Can anyone tell me how to remove my steering wheel?
  60. 98 Civic LX -- Transmission Problems
  61. cam gear or camshaft.?
  62. cx v dx??
  63. CEL with P0420.
  64. Lip Kits?
  65. Can a bad CAT cause any engine damage?
  66. Cylinder 1 random misfire
  67. engine
  68. VTEC or not?
  69. P1361 &P0420 Please Help!!!
  70. This is the end...
  71. SI to EX engine swap
  72. Help!
  73. Newbie Question
  74. Hard window streak (pic included)
  75. New Rotors and Pads! HELP!
  76. Help me with fixing up my car :'[
  77. Another problem what a surprise
  78. 99 Civic Weatherstripping
  79. 2000 civic si
  80. What did I break???
  81. D16Y8 - Missing Screw on top?
  82. 94 civic no check engine lightr
  83. My Honda seems to have the Hiccups??? Any ideas??
  84. Possible Serious Issue!!!
  85. Lowering Questions. Please help :)
  86. Help! Turn signals!
  87. OBD Sensor wont read
  88. Manual
  89. Overheating with A/C on
  90. How do I install aftermarket tail lights?
  91. Interior Wiring
  92. Best intake for 97 civic?
  93. New member, first civic
  94. 96 hatchback door conversion
  95. What is the BEST Exaust????
  96. engine swap??
  97. Up down Up down
  98. Things to Upgrade
  99. OEM Spoiler and Shifter questions
  100. Help....clunking then I filled tranny fluid and it leaked out the axle?
  101. hood latch stuck
  102. window visors
  103. code 1508
  104. Name for trunk thingy
  105. Wtf is this ? :o
  106. What would be a good engine setup??
  107. Any civic sunroofs????
  108. Fog Lights Help
  109. LCD FP Plus caused car to not start?
  110. How often to change oil?
  111. Gameshow: Name that wire connecter!
  112. oil pump problem
  113. Need help understanding self dianostics
  114. help please
  115. looking for a d16y8 head..
  116. HB wing on sedan
  117. any cluster mods?????
  118. Stock Air intake question
  119. 1996 Honda Civic 2 Door Hatchback DX
  120. New Owner, Please Help
  121. D16 engine swap
  122. What to look for when buying?
  123. overheating help!
  124. Indicator side mirrors for EK?????
  125. RPM GAUGE question
  126. 00 SI cluster(speedometer) light
  127. Engine Side Mount: P/N HELP!
  128. Front Seats Change out Query????
  129. 89 civic LX question
  130. Changed Valve cover gasket now engine has noise. HELP
  131. Exhaust Swap
  132. Cooling Fan and AC
  133. hey guys its been a while ...QUESTION?
  134. 1998 Civic Dx Hatchback AC HELP!!!
  135. coil over question
  136. Some questions.
  137. Question about my engine
  138. Just finished Transmission drain & fill on my '98 LX
  139. 98 EX fades at first start but then is Ok..
  140. Intermittent starting problem
  141. Can a 2000 Honda Civic EX Sdn Use Wheels in Bolt Pattern 4x101.6, 4x114.3?
  142. '96 DX sedan upgrades
  143. '96 DX sedan upgrades
  144. Inner moulding smearing window
  145. Misfire and Rough Idle
  146. Spark plug fouls
  147. Power door lock nightmare -98
  148. 1997 1.6SR driveshaft splintered.
  149. Huge metal shavings are what i like to see...
  150. Stock Airbox new Intake
  151. difference between Canadian and U.S. models?
  152. B20 Vtec
  153. '96 center console in a '93
  154. Rear Speakers
  155. Antenna problems
  156. Hi yep im a nub First time honda owner other then a lawnmower. Vtec or not vtec
  157. 5 lug conversion for 6th gen
  158. Looking for hp gains please help...
  159. Indicator side mirrors for EK?????
  160. A frustrating speaker issue (DB 651)
  161. rim/tire size
  162. KYB GR2 on civic 96 question
  163. After market rear view mirror
  164. What other parts should I replace to improve reliability/durability/MPG
  165. Interior fan
  166. Crankshaft position sensor question
  167. Engine rev fluctuates
  168. Severe loss of power/acceleration - Looses speed uphil
  169. EK Foglight Conversion?????
  170. Engine seems to be holding back on accel
  171. freshly rebuilt d16y7 problems help please!
  172. Exhaust pipe dimensions for 1998 HB DX
  173. Are the stock radio antennas retractable or non-retractable?
  174. foglight overheating!
  175. 98 civic hatchback seat belt
  176. Can american parts fit into japanese cars?
  177. Engine swap
  178. D16Y8 engine slowly falling apart
  179. vtec problem
  180. AEM under drive pulley kit (aem 23-7000B)
  181. Can I see some pictures of your car?
  182. Oil leak - very fast
  183. 1998 HB DX - Back hatch (3rd door) closes unevenly
  184. B18 engine swap
  185. Spent $1,500 trying to solve this......
  186. Idle revving up and down in park
  187. 2000 si
  188. Tire shop tells me I need "rear camber arms"?
  189. 1997 Civic Coupe Power Window Problem
  190. Body kit question
  191. New Steering wheel
  192. Need help with erratic idle after engine warm.
  193. Rate my spark plugs
  194. 96 Civic 1.6L turns over but won't start
  195. Car is completely dead
  196. Doing front oil seal on crank on my 97 civic?
  197. 98 si
  198. Is my '98 LX a CVT or not?
  199. Transmission fluid dipstick loose?
  200. 6 speed?
  201. HELP! engine sputter and backfire??
  202. Normal Spark Plug?
  203. Opinion on lowering springs???
  204. Convert to 4 Disc wheel???
  205. Pulling trouble codes
  206. Motor mount weld
  207. anti theft or keyless entry?
  208. VTEC ? & Motor oil
  209. Blower Motor Relay
  210. 94 civic breeze 1.3 hatch manual. what can i do with it?
  211. Seat Replacement alternative for '98 Civic LX
  212. shakey rpms!!
  213. Radiator Leak
  214. Strange OBD code / 02 sensor diagnosis
  215. Brake pedal sinks to floor?
  216. Securing license plate bottom....
  217. idle drops, lags when accelerating.
  218. Question for anyone who has experience this
  219. sqeeking noise while driving
  220. weird issue.. help please!
  221. Blinking CEL, puttering/no power
  222. Check Engine Light problems
  223. Does size really matter?...You tell me.
  224. Where does this connector go?
  225. 96' Civic EX w/ 06' RSX CF Wing???
  226. Does my car have a Vtech engine?
  227. Just bought a Civic-- (Need help)
  228. odd loss of power issue
  229. First Civic?
  230. acceleration lag!!!
  231. timing belt replacement-2nd time
  232. 98 civic ex randomly dies help plz
  233. newb here need help with swap
  234. 99 hood on a 97?
  235. .....!?
  236. 2000 Civic SE (Canadian LX equivalent) RIMS HELP!
  237. clutch noise ?
  238. 1998 DX Coupe
  239. Maintenance Required
  240. some educational help!
  241. Transmission Help
  242. Throttle Cable Adjustment?
  243. So, here's an interesting one...
  244. Wiring up a tachometer
  245. low idle
  246. Hondzilla
  247. Motor dies occationnaly?
  248. ECU Reset?
  249. Odd Acceleration..
  250. switching oil grades
