New Owner, Please Help
Old Aug 27, 2010
Macgyver's Avatar
Macgyver is an unknown quantity at this point
I just purchased a 97 Civic LX. There is a random plug connector that I don’t know where it goes. I took a picture so you could see. Also, I have 6 engine codes that I’m hoping aren’t huge repairs. They are P1607, P0108, P0122, P0113, P0141, and P0453.
I’ve worked on cars, but mainly domestic. Can anyone point me in the right direction on how to fix these codes? The car seems to run very well.
http://i41.photobucket.com/albums/e2...b/IMG_5330.jpg
Old Aug 27, 2010
lazlong's Avatar
Re: New Owner, Please Help
Is that a 2 wire connector? If it is it could be the IAT.
Old Aug 27, 2010
lazlong's Avatar
P0108- MAP circuit high voltage
P0113- IAT cicuit high voltage
P0122- TP cicuit low voltage
P0141- secondary O2 sensor cicuit malfunction
P0453- FTP cicuit high voltage
P1607- ECM/PCM internal circuit malfunction
In every troubleshooting index I'm seeing it's leading back to the ECM/PCM, especially with the P1607 code. You can try to have a speed shop reflash your ECM/PCM, usually costs about $100. If that doesn't work it's probably a bad ECM/PCM, go to http://www.car-part.com/ and get a used one and have it reflashed. Or you can just go to the dealership and pay $1500 for a new ECM/PCM.
Good Luck.
Old Aug 27, 2010
Macgyver's Avatar
Can the ECU really be bad if the car runs well? Other than me checking to see the codes, I wouldn't have known there to be any problem.
Old Aug 28, 2010
Macgyver's Avatar
And I hate that yellow intake. Is that the OEM intake I assume they just painted? It looks ugly and I'd like to replace it, but don't know what kind I have.
Old Aug 28, 2010
lazlong's Avatar
I have no earthly idea. sorry.
That's oem intake. Just take it off and strip the paint.
Old Aug 28, 2010
Macgyver's Avatar
Thanks for the help so far. If I buy a used ECM off ebay that's for my car, do I have to program it?
brags
Oct 2, 2015 05:53 AM
Hutch1051
Sep 29, 2015 09:20 AM
dhuff
Sep 28, 2015 08:35 PM
Nalmonte
Sep 28, 2015 01:10 PM
Sep 27, 2015 11:33 AM
