Check Engine Light problems
Old Jul 8, 2010
broyoon's Avatar
broyoon is an unknown quantity at this point
In april 2010 my check engine light came on.
The computer code for the light is P1457 and the probable causes are:
loose fuel cap,
vapor canister saturated,
failed vent solenoid,
and failed purge solenoid.
I had a mechanic pinpoint what the problem was and he said i needed to replace the Evap. bypass solenoid.
In May 2010 I got that part replaced and then a few days later the light came back on again.
Does anyone know what could be the problem? I've already spent so much money at the mechanic I don't wanna go again until I do some more research.
Old Jul 10, 2010
jziegler25's Avatar
jziegler25 is an unknown quantity at this point
Re: Check Engine Light problems
you should take it back and have them pull the codes again im a mechanic at a big name shop and if i had done the work i would have to recheck it for free....so they should recheck it for free since they told you it was that part
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
