- Help,help,help!!!!!
- Newbie needs help please, car won't start
- Looking to be a little rediculas...
- Ek guages need help
- Hi folks! I'm new here
- moisture in headlights
- 17" rims
- '97 3dr DX Stalling
- good chip
- need help to identify which transmission I have
- '97 EX: AC Problem
- p-73 Ecu
- wheel fitment on a 97 civic
- hello
- TSX Retrofit w/ H1 Hi-beams, Wiring help needed
- 2000 honda civic HX, Flasher problem.....
- 97 civic hx tranny shot
- what year/model to buy (6gen HB)
- E-brake handle
- Resetting Check engine light?
- Air/Fuel Gauge Install
- front clip swap
- Frustating!? Help Me Someone!
- 99-00 Civic Si Rims
- engine swap for beginners
- Sticky accelerator
- As far as headers and exhaust go...
- Spark Plugs for HX..
- 95 Civic antenna replacement
- climate controls messed up
- NooB Question.
- help- clunking noise
- VTEC Question
- suspension help
- Just got a 2000 Civic Si
- I was wondering...
- Magnetic drain plugs
- Turn on ac at idle speed, engine shuts off
- New User 2000 Honda Civic Si
- transmission suggestions
- drivers side seat not reclining
- Suspension
- Fan problem
- Where can I find this piece of trim?
- which ECU?
- 96 VTI ECU seems has Problem
- Axis Oldskool Rims
- 97 Civic LX, Need advice on CV Boot repair / replacement
- How to spot a cracked head...
- most effective SOHC Vtec bolt ons
- 98 ex turbo.. t25? any?
- help w/ wiring m3 mirrors
- DTY removal of rear spoiler
- Suspension advice
- 98 civic ex cold air bypass valve
- Injen, Skunk, K&N, or AEM Cold Air Intake
- Would the K24's weight trough off the handling dynamics
- 1998 Civic EX 1.6 - I have a number of Codes. Need Help.
- Springs for '00 Si
- 98 Civic Ex Gas Guage Nd Brakes
- quick question
- check out my ride and tell me what you think
- wut kind of exhaust should i get on my 99 dx
- Just bought a 1997 civic coupe and got some questions
- 99 ex clutch swap problem
- cant get past 4k :/
- just picked up a 98 coupe
- Is it a wise to add performance mods to automatic HX?
- 97 HX with strange electrical gremlin
- Speedometer not working post swap
- civic 2000 ex noisy using s2000 cluster mod
- bumper replacement
- decat pipe
- Looking to boost my d15b
- 98 civic exhaust choice...
- Need headlight help
- OBX PULLEY 98 civic LX
- Drag Racing
- d16y8 build?
- Removing Front bumper
- Clicking/Rattling noise front of car, not speed/rpm dependent
- how do you put the door panel on?????
- 98 ex want to upgrade cam
- Most bada$$ engine
- overheat issue
- 1997 dx d16y7 NOT GETTING SPARK
- Was This a Waste??
- 6th gen power problems
- P1457 - Manufacturer Control Auxilary Emission Control
- 98 honda dx tail light lens replacement
- driver's side power window
- Cold starting problem
- auto or stick?
- VTec Questions
- 2000 Civic DX rear disc swap help?
- tough decision pt 2 lol
- BBP clutch kit, questions?
- How do you bleed coolant system on 2000 si?
- fuel injector? 98 civic ex how to replace?
- $1500 to replace brake lines -too high ?
- Debris blowing through air vent.
- I need a D16Y8
- remote starter troubleshoot
- 98 civic won't start after sitting 12hrs or more
- e-brake help!
- 1996 EX Engine Help
- 97 civic auto tranny problem
- Evap Canister Location?
- Honda Civic AT trans shifting problem...holding 2nd gear for no reason
- 2000 Civic Sedan OEM Clear fog lights
- D16Y8 engine swap ??
- 1997 Honda Civic Help Needed (Bumper, windows)
- '99 Civic EX 5spd lacking torque
- Installing headers
- would a catalytic converter from a 1998 ex work for a 1997 hx
- Urgent. Car not starting! Need Help
- 99 civic grill swap
- D16Y8 N/A Build Help
- Low on power and dead spots????
- Clutch Adjustment
- Harsh Shifts
- Engine/Acceleration related noises. Mechanic couldn't duplicate, help!
- 1998 LX Exhaust
- 2000 civic si motor?
- 1996 honda civic ex with 5spd swap
- 99 civic hx exterior project
- enigine burning oil
- suggestions?
- 98 civic HX
- Engine noise due to timing belt tensioner ?
- Integ seats
- WHY won't my wheels come off!?
- Temp gauge issue?
- Shift Knob/Shift Boot Fix
- Tranny/Clutch Problem!
- effin B16a
- rimz ?
- Where to find color matched side moldings/mirrors/handles?
- Estimates...
- Throttle Response gone ........................... :(
- Location of the O2 sensor for a P0141
- D16y7 Head Change
- D16Y7 What will it fit in?
- 98 Civic sometimes won't start or stalls
- Engine failed to start and awkward noise heard
- keyless entry
- Gold Rims and Tint
- just picked up my first honda
- Abs
- MOTOR BUILD. B16 or D16 turbo
- Coilovers
- OEM (?) Tail light Issue
- problem with ballast
- Spoilers
- i need to know something about a site before i drop cash
- my effin door latch
- small prob with my door latch
- pics of trunk struts needed
- 99-00 stereo surround/bezel - where to buy?
- pw steering
- Keyless Entry Problem
- 01 automatic tranny problem
- 96-00 ex rear disc conversion?
- "Under engine splash guard"
- Suspension Noise
- 01 Civic gauge Problem
- Keyless Entry
- My Introduction.
- Busted Gauge Needles
- hello to everyone
- Need to know stock ride height of 98 civic
- tucking front wheels into fenders
- Does anyone know how I can paint my brake calipers?
- intallation help for AEM short ram on 98 civic lx
- unknown problem..??
- D16y8/d17 stroker
- Strange rattling noise from engine when letting out clutch
- Window Problems
- 98 civic lx 200k miles yes or no?????
- Opinions on these wheels
- New 2000 civic lx. Installed pioner H.U now interior lights dont work! Please help!!
- Shes finally done!
- Question about manual transmission compatibility
- Would you recommend this civic?
- Sway Bar question
- 02 Sensor
- 1999 Civic H22 Swap.
- 2000 hx interior
- broke down si
- fix ecu
- ebay turbo
- Interior questions
- Popping noise when I turn my car
- Remote starter help
- 1997 Civic EX Coupe AT
- Oil Pan Replacement?
- 98 civic manual trans removal help
- How Do i get rid of the cruise controll?
- looking for mass air flow sensor
- Winter hates me!!
- power window problem on 1997 ek
- 6th gen mileage
- 05 cluster swap
- Transmission compatibility
- catalytic converter
- Wtb: B18b Ls
- Drag Wheels
- 96 Civic Problems
- Fuel pump?...or? please help!
- Intermittent Belt Whine
- new 98 civic lx owner!!! I was thinking..
- whistling noise again
- Help. The bottom Fuel Filter nut would not loosen
- loose shifter
- Location of VSS wire 1998 Civic EX
- Rust on bolts on exhaust manifold cover
- 92 LX oil leak
- leather seats
- wont start
- hids in projectors
- New car and new mods
- map sensor
- whistling noise
- 98 Civic LX power window problem
- what is the benifit of using a one step colder spark plugs?
- H series in da EK 5 lug and stuff
- air coming out of the engine Oil Cap
- Cant pass CA smog- Engine light-wont throw right code? help asap
- $500 how to spend?
- 1996 Civic wiring diagram for Turbo Timer
- Ran out of gas, now car runs like crap
- Airflow??
- turbo time...
- Ebay EXhaust would this work
- My brakes suck
- flowmaster muffler
- 2000 civic VAFC settings?
- CrankShaft Sensor
- aftermarket for b16a3
- Gas Performance in Cold
- Paint code for 2000 Black Civic coupe
- headlight bolts
- Ignition wire
- Overheating. HAs me stumped
- 00 VTEC exhaust manifold same as 96-98 VTEC?
- AEM short ram on a 98 LX
- civic idle problem
- 1997 honda civic CX HB, body kit
