Cold starting problem
Hi All,
I have a 96 Civic Si (Canadian) which has a hard time starting when the engine is cold in the mornings.
When I start my car first thing in the morning, the engine fires up but within 1-2 seconds of starting, the RPMs drop and the engine stalls. I have been able to work around this so far by slightly holding down the pedal after I start the car to keep the engine at around 1,000 RPM... after holding it here for a few seconds, I can take my foot off the pedal and the engine will idle normally.
This problem only occurs when I first start my car every morning. Throughout the rest of the day, the car will start fine. Once the car has warmed up, I will not have this problem.
Re: Cold starting problem
Bump, I posted this last March. However, once the weather warmed-up this problem went away. Now, almost a year later, the weather has been getting very cold again and this problem is occuring again. Anyone know what could be causing these rough starts while cold? I have to hold the gas for about 10 seconds after cold starting so the engine won't stall.
our accord does the exact same thing. ive been told its prolly the main relay. open it up and resolder the connections.
Well it's been 2 years since I made this post, but I have finally found out what was causing this problem!
I had a dirty IACV valve - I cleaned it using the instructions I found on another forum:
http://www.hondacivicforum.com/forum...leaning-62836/
Problem solved! My Civic is idling perfectly now.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
black2k1vtec
Dec 6, 2001 09:49 PM
