6th gen power problems
Old Mar 16, 2009
sjrd3387's Avatar
sjrd3387 is an unknown quantity at this point
I have a 99 ex with a few problems....
First, when im idling sometimes the rpms drop down to like 400 and it almost stalls out then it goes back up to around 800
Second, When i get into gear the car feels like it has no power and kind of boggs out for a second untill i get the rpms up, this usually only happens in 1st and 2nd but 3rd sometimes does it (b4 someone says it, i know how to drive a manual this happens after im already in gear, foot all the way off the clutch) does this sound like a clutch problem or an engine problem? i do have a code right now it's P1457 - Manufacturer Control Auxilary Emission Control (near canister) if a lack of gas or something would cause that...and on the code subject, does anyone know if that would more likely be the EVAP canister itself, the vent valve, or the purge solenoid?
Old Mar 17, 2009
Re: 6th gen power problems
its hard to say for sure on the emissions part, but those things are only for vapor recovery and should not affect how the car drives. more than likely you need to take apart and clean your intake system, throttle body, idle air valves, and see if that fixes it. most likely thats causing the low rpms and bogging.
Old Mar 18, 2009
ridebmx1664's Avatar
ridebmx1664 is an unknown quantity at this point
i just had the same problem in my 2004 se....low rpms and bogging out...i drive an auto ( booo..i know ) but its the same problem...i think....take a look at the Idler...i just took mine to honda after i looked at everything..and then they said that wore out...under warrenty still ...cuse it will cost 500 bucks...
Old Mar 18, 2009
sjrd3387's Avatar
thanx guys i'll check it out and post some results
Old Mar 19, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
Wow, just noticed the rpm dropping too. It was driving fine, then pulled into parking space and put it in neutral, ebrake, let off of clutch and started listening to radio for a bit then the freeking engine shut off. That's the first time that's happened. Turned the car back on and the rpms slowly drop, and keep dropping...
Old Mar 19, 2009
Bah...just got my civic back from the dealer...they had to order the part...price ended up coming to 426$...thank god for extended warrenty
any news on both problems?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
beveragemp
May 25, 2015 07:11 PM
cperez53
May 1, 2015 06:15 PM
Rardon6thgenCiv
Apr 15, 2015 07:37 PM
02Si
Dec 10, 2001 04:56 PM
