Ek guages need help
Old May 16, 2009
flyboy1304's Avatar
flyboy1304 is an unknown quantity at this point
Ek guages need help
Hey all, I picked up a DX ek, It doesnt have a tach beacuae its a DX, However i found an EK civic guage cluster for cheap, it is complete, Will this be a direct plug in swap? please let me know how hard this swap would be... any input would be appreciated. thanks
Old May 19, 2009
sql_civic's Avatar
Re: Ek guages need help
Yes, this is a direct plug in swap and can be done in about 30 minutes.
Just remove the bezel. Then unscrew the cluster (4 screws) and unplug it. Swap the speedometer if you want and then just plug in your EX cluster.
You might want to swap the speedometers so you can keep your odometer reading. It can just be simply unscrewed from the back.
Old May 11, 2011
hotrod_714's Avatar
hotrod_714 can only hope to improve
I have a similar question. i have an ek ex and im wanting to swap in si guages (tach and speedo) if i swap those in will that also be a direct swap, eventhough the speed goes to 140 instead of 120 and the tack goes 1000 rpms higher? do i have to replace any gears or anything?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
Dave Brabant
Sep 10, 2015 06:48 PM
brennov8
Jul 13, 2015 12:57 PM
notorrious
Jul 15, 2002 02:49 PM
