front clip swap
Old May 2, 2009
stopspazinout's Avatar
stopspazinout is an unknown quantity at this point
front clip swap
hi im trying to do 99-00 front end swap on my 97 civic and i was just wondering if the radiator core support needed to be swapped or modified or just left as is for the front bumper mounts.
Old May 2, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: front clip swap
Compare Honda part numbers (not the short Honda code) on www.hondapartsdeals.com. If they match, they are the same (my gut feeling is they are in fact, the same).
Old Jan 12, 2010
98sLicKvIc's Avatar
98sLicKvIc is an unknown quantity at this point
Re: front clip swap
All you need is the bumper, headlights, and fenders. the hood will fit any ek.
Old Jan 13, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: front clip swap
I went to majestic hondas site, and noticed that a 96 civic coupe has a different part number than a 99 civic coupe.
I just looked at 99 and 96 different hoods.
Old Jan 14, 2010
ScottDR's Avatar
Re: front clip swap
Majestic uses the Honda Code number, not the actual part number. As mentioned before, go to www.hondapartsdeals.com and compare full part number.
Old Jan 16, 2010
civicpapi's Avatar
Re: front clip swap
No, I had a 99 civic parked next to mine 96 and looked at the hoods, the 99 is different because the grill is different and lines of the hood will not match. Hard to explain but the front of the 99 is narrower where the headlights meet since the 99 has a wider grill.
Old Jan 17, 2010
ScottDR's Avatar
Re: front clip swap
Ok, the initial question was about the radiator support. That would indeed be the same part for both cars. Of course the hoods/grills/bumper fascia/fenders and headlights are all different. Otherwise why would they want to do the swap?
Old Jan 18, 2010
dnice78's Avatar
dnice78 is an unknown quantity at this point
Re: front clip swap
Is exactly correct, you need bumper, headlights, fenders, and hood. I would assume some minor drilling would be involved. but original rad support should work.
Burnout
Jul 15, 2022 10:24 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
usajags84
15
Aug 19, 2015 03:12 AM
