Prestone leak ?
Old Jan 18, 2010
SirCharlo's Avatar
SirCharlo is an unknown quantity at this point
Prestone leak ?
Hey Guys,
I was rolling along yesterday, heading to my friend's place, and i noticed this awful (prestone?) smell coming from my 96 civic. When i stopped at a light, a bit of smoke was coming from the right side, in front.
After thinking a bit, i remembered that i had dropped a bit of oil on the motor when i filled it up the last time i used it. So i said to myself, it's just the oil burning off. So i went on to my friend's.
When coming back, the smell and the smoke had stopped ! So my suspicions seemed confirmed.
BUT...
My dad took the car today and the same thing happened to him: smoke and smell.
Now i'm glum cuz i have to possibly fix a cracked radiator, right ?
Any ideas ? Should i just dump the poor thing ?
Thanks
Old Jan 18, 2010
Re: Prestone leak ?
any fluid leaking on the ground or on the exhaust pipe?
Old Jan 18, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: Prestone leak ?
A common site for a radiator leak is from the top seam. If that's what you see, then replace the radiator, which costs about $100 and is a relatively easy job to do yourself.
Old Jan 19, 2010
Acidsniper's Avatar
Acidsniper is an unknown quantity at this point
Re: Prestone leak ?
This is the same thing I had happen to me. The radiators from the factory are junk and mine broke the seam right at the top where the aluminum is pinch "welded" to the plastic. I initially tried to JB Weld it up to no avail. Just replace your radiator, and while your at it do the thermostat, lower and upper hoses. I replaced it all in about an hour and it cost me about $100 shipped from RockAuto.com.
Removal and installation is REALLY easy.
1. Drain Radiator using the drain plug
2. Pull off Hoses
3. Remove the 1 Bolt on raditor hold support
4. Pull out overflow bottle and disconnect hose
5. Disconnect Fan Plug
6. Pull out radiator
7. Transfer fan to new radiator
8. Take off 3 bolts on thermostat housing
That's about all that was required that I can remember. Installation is the reverse. Very quick and simple replacement and worth it IMHO.
Old Jan 19, 2010
Re: Prestone leak ?
did you get a different brand radiator, or was it another stock part?
GritzNGravy
Aug 19, 2015 03:03 AM
cukaracha
30
Jul 26, 2015 12:01 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Kyles24
Jul 16, 2015 10:14 PM
Causemo
Jul 5, 2015 06:42 AM
