97 civic auto tranny problem
hello guys i recently purchased a 1997 civic EX with a 1.6 litre vtec and auto trans for a gas saver... i did an engine swap and the thing runs pretty decent now... but my D4 light is blinking?? from what i understand it is like a service trans soon light or something.... anyone have any ideas what that could be
Re: 97 civic auto tranny problem
Check for any loose or cracked electrical tranny connections, first. Make sure all hydraulic lines are installed properly- nothing reversed. Check fluid level - make sure you are using Honda fluid not a knock off. You might have to reset the light- is all.
Look for the obvious because that's usually what it is on civics.
this damn car has given me so many problems... the codes are p0700 and p1758... the transmission seems to shift fine for a honda but i dont think the torque converter is locking???
Ok, yes those codes indicate 'lock up clutch does not engage'. Possible causes (just as we stated-loose wires): A) Disconnected lock-up control solenoid valve B connnector, B) Short or open in lock-up control solenoid valve B wire, or C) Faulty lock-up control solenoid valve B.
I can't really type the instructions on how to track it down (it has diagrams). I can almost guaranty any problems you are having are due to loose/corroded connectors to the transmission/transmission ECU.
It's on top, yes. The 2pin connector is right there. Measure resistance between both terminals and body ground. This should be 14-25ohms. If that's within spec, the solenoid is fine. I'm still guessing connection somewhere.
Just out of curiousity, did you unplug and replug it a few times? If so, do an ECU reset procedure and see if you still have the codes. That might fix the problem. If not you can get a solenoid at a local dealer or on-line. There are several Honda dealerships that sell the parts on-line, but know that shipping and handling can sometimes make or break the cost savings difference. Not sure but some auto parts stores may also carry them *shrug*.
PS there is also a shift solenoid filter that is sandwiched between the solenoids and the transmission housing. I'd even try replacing that before buying a solenoid!
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
dooner24
Apr 14, 2015 07:51 PM
