How to spot a cracked head...
Old Apr 10, 2009
juxstapo's Avatar
juxstapo is an unknown quantity at this point
'96 EX. Been losing coolant for a few weeks. Haven't had the money to address so I've been checking levels every time I stop rolling. This time its been different:
Check car, everything is fine...
Head up the road, temp gauge is good..
Get where I'm going, about fifteen miles total, come to a stop... get steam from under the hood and the temp gauge starts a steady climb.
Pop the hood, find coolant percolating from between the head and intake manifold. Firewall and various whatnots behind the motor are wet.. so tell me...
Have I cracked my head?
Old Apr 10, 2009
Re: How to spot a cracked head...
its hard to know without taking it off and getting it checked at a machine shop. maybe its the intake manifold leaking? is coolant leaking anywhere else other than head/im? does the oil look normal?
Old Apr 10, 2009
rednwhite04's Avatar
rednwhite04 will become famous soon enough
maybe your head gasket just took a ****?
Old Apr 11, 2009
juxstapo's Avatar
Compression check turned out fine, so the head gasket should be cool. Took the intake manifold off and that gasket is gone, no coolant loss anywhere else. buut...
Oil looks great at the dipstick and under the valve cover, but at the head/intake mounting surface, that chamber inbetween the intake runners (2 to the left, 2 to the right, what I assume is a coolant passage in the middle). In that hole there's this milky coolant/something conglomerate. But I think its RTV or whatever, the old intake gasket was globbed with it.
In the process of getting the IM off, popped the fuel rail off... and broke the plastic cap off the end of one of the injectors.
The injector closest to the trans (is that #1?), brown plastic cap on the needle end, very brittle on that one injector, the others are fine....
is this replacable or am I ordering a new injector?
Old Apr 11, 2009
if the plastic is part of the injector, its not sold separately. just replace that and the manifold gasket and hope everything is fine.
Old Apr 12, 2009
magikshark's Avatar
magikshark is an unknown quantity at this point
i wouldnt think is the head.have a look at the oil,if its kinda white foamy gunk floating in the oil then it could be cracked!
Old Apr 17, 2009
sql_civic's Avatar
Do a leakdown test. A compression test ain't gonna tell you much.
styles234
21
Nov 19, 2019 07:23 AM
raymondxcho
Sep 29, 2015 09:00 PM
rovafa2002
Sep 28, 2015 06:57 PM
