Gas Performance in Cold
Old Oct 29, 2008
mdawg's Avatar
mdawg is on a distinguished road
I know that MPG is suppose to decrease in cold weather but come on my avg went from 32 to 26. Its almost all Highway with commuting to school 5 days a week at around 75mph avg. This normal?
Old Oct 30, 2008
Re: Gas Performance in Cold
i get 40mpg in the summer and 32 in the winter all highway miles. yeah its pretty normal. colder air means more fuel being used to get the correct a/f ratio and keep the ecu happy.
Old Oct 30, 2008
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
try using super it burns slower therefore you get a more complete burn with that dense air in there. yea it costs a little more but i bet you go farther on the tank.
Old Oct 30, 2008
you get a more complete burn using 87 in our engines.
Old Nov 2, 2008
sql_civic's Avatar
That's interesting. I've never experienced a 20% reduction in gas mileage from cold weather in a Honda driving in CT. When's the last time you did a tune-up?
Old Nov 15, 2008
mdawg's Avatar
Only things I did to it over the summer was Filter,Plugs, and Fuel Filter.
Old Nov 16, 2008
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
What about distributor cap? Rotor? Plug wires? My gas mileage went down too btw, but only to ~34 highway and I normally get 38 in warmer weather.
Old Nov 17, 2008
mdawg's Avatar
Havn't touched those. Btw when the engine is cold it seems to be burning a lot of oil. Since it has been cold lately I normally give it some gas to about 3k when it first starts up and it just rolls white smoke out of the exaust or If I floor it before the engine is warm I can see a trail of white smoke down the road. Yet once the engine is warm it stops? It does this anytime the engine is not warm(even in the summer).
Old Nov 18, 2008
What do you mean when it first starts up? Like literally? The engine automatically takes you to 2000rpm through the IAC valve, and you shouldn't give it any more gas beyond that. It takes 1 minute to pump oil to the top of the engine, and after that if you want to warm up the car just drive it.
Old Nov 18, 2008
when i cold start the 92 accord, in cold weather, alot of times the idle will rise and then suddenly fall and shut down unless you hold the gas pedal for a while. im guessing the iac is clogged again.
Old Nov 19, 2008
mdawg's Avatar
I realize that but still even at 3k for a few seconds I don't get why its burning oil only when its cold. Or anytime I put it too the floor.
Old Nov 19, 2008
have you done a leakdown test? it could be worn valve guides but also the piston rings could be bad. compression test? are all cylinders making close to the same psi?
Old Nov 20, 2008
mdawg's Avatar
It will be a few days before I could take it to have a compression test, if it makes a difference until its warm it also sounds like its knocking like mad.
Doug Lassiter
Jun 21, 2015 01:53 PM
freyes23
Jun 21, 2015 10:37 AM
jc33312
May 12, 2015 03:17 PM
bsmiley
Apr 27, 2015 01:27 PM
onelifetolive
Bolt-on Engine Performance
Nov 10, 2001 10:58 AM
