Temp gauge issue?
Old Feb 10, 2009
WKD DRGN's Avatar
WKD DRGN is an unknown quantity at this point
Temp gauge issue?
I'm more of an auto body tech than a mechanic, so I'm not sure what's up with my Honda.
Sometimes when I drive, and am idling, say at a stoplight, I'll notice the temp gauge needle slowly rising up to the red area but not into the red area. When I start moving again, the needle goes back down to normal range. It's only happened about 3 times, but it worries me either way.
I checked the coolant level today and it's below the min. line in the plastic resovior (about 2 inches) and I can't see any coolant in the radiator. The oil level seemed normal when the car was running warm. So is it just reacting to low coolant or is there another problem like a blown head gasket?
Old Feb 10, 2009
sql_civic's Avatar
Re: Temp gauge issue?
You should start with adding coolant. Top off the radiator when it's cold and add coolant to the res so it's between the min and max level. Then check it again after you drive it and it cools.
What year Civic? Some require bleeding.
A blown head gasket would be indicated by white smoke out the exhaust, grey coolant, or grey oil.
Old Feb 15, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
I agree with sql on their advise above. If it's indeed a 6G, they don't need to be bled. Another thing. If after filling it properly it gets hotter and hotter at stoplights, the thermo switch may have been cooked. They are relatively cheap and an easy fix.
Otherwise if you gobble down tons of antifreeze soon after filling, the head gasket may be to blame (typically you'd see white smoke or very rough running at startup as stated above).
Let us know what you find. Good luck!
Xuhme
21
Aug 7, 2023 03:40 PM
brian257
Jun 4, 2015 08:17 PM
zaboomafoozarg
May 30, 2015 09:21 AM
tylerginevan
Apr 27, 2015 12:29 PM
jmythngdmb
Jan 24, 2002 03:10 PM
