PDA
View Full Version : 6th Generation Civic 1996 - 2000
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17
  1. D16Z6 into 6th gen 00' civic?
  2. Wetness on passenger-side floor
  3. A/C clutch removal
  4. 17 yr old's B16 project ! turbo help!
  5. Strange wire A/C qusetion
  6. 2000 Honda Civic Wont Start
  7. Can I use this head?
  8. Running hot
  9. window problems
  10. 1998 EX 5sp A/C HELP It's Hot!
  11. radiator support
  12. My new project
  13. New Window tints !
  14. Connecting rods
  15. Car smells like pot
  16. Speaker install in dash (or other options)?
  17. Seafoam?
  18. Need Help: 6.5 Speaker won't fit front door
  19. Got one for ya, boys
  20. Fond Farewell: Goodbye Frankenstein
  21. I need an owners manual...
  22. Need to replace leaking transmission oil seal for driver-side axle
  23. exhaust question
  24. 2000 EX not starting. Out of ideas. plz Help!
  25. New Civic, Need some suggestions
  26. Rear sway bar questions
  27. B18b swap question
  28. Braking system serious problem!!
  29. replacing the front grill 2000 civic se w/ acura 1.6
  30. What's a good engine swap?
  31. Help!
  32. Bang for your buck.
  33. new here, radiator issue?
  34. Alignment Problem, Need Help
  35. 99civic with d15b block
  36. Where is Main F.I + Fuel Pump relay
  37. Which civic gives the best MPG?
  38. Trans sticking?
  39. Spark Plug pic and concern
  40. Lowering
  41. used ignition coil
  42. Harness installation
  43. D16Y7 block with D15Z1 head?
  44. Headlight type 2000 Civic SE (Canada model)
  45. Decrease Body Roll
  46. Gutted vs non gutted
  47. Vent Window Replacement
  48. cai or exhaust??
  49. I need help.... On my 99 civic asap please...
  50. My 2000 civic si keeps dying on me while i drive. Urgent help please!
  51. ignition coil ohms
  52. Dnice's Build....Turbo by 2011!
  53. D16Y8 hesitation and other problems
  54. intake help
  55. Please help! Why is my gas mileage so bad!?
  56. location of ignition coil
  57. AC Condenser Repair?
  58. Stumped on IAC valve
  59. I am so worried.
  60. fuel issue
  61. doesnt wana go in reverse
  62. ABS Flashing while in diagnostics mode
  63. Fix stuck rear windows
  64. 2000 Civic EX ... Brake lights wont work!!
  65. CEL 67: Cat Converter !!!
  66. Need some help with fogs
  67. power window problem
  68. 1998 LX Stalls
  69. what are these parts called? on fender + hood, pic!
  70. buying a used civic
  71. 99 Civic Keyless Entry Programming remote control help
  72. H22a4 swap ecu help
  73. 1998 Honda Civic EX (keyless or factory alarm)?!?
  74. B20 question???
  75. D16Y5 SOHC Engine question
  76. brakes making noise (very vague but check the thread for info)
  77. 98 not starting
  78. Stuttering sputtering stumbling...?
  79. hid problem
  80. exhaust ?
  81. questions on engine swaps...
  82. Skunk 2 coil overs
  83. engine swap
  84. replacing stock stereo with head unit
  85. Bronze or hyper black rims?
  86. bulb housing/ballast for depo headlights 2000 civic
  87. 2000 Civic rear door lock issue
  88. led dome light
  89. new in town
  90. Rev Limit
  91. Planning a midwest/chicagoland meetup!
  92. '98 Honda Civic EX questions
  93. Removing injector wires cover cap?
  94. Recovered my 2000 EX that was STOLEN. Before & After. Advice needed!
  95. Oil Leak
  96. crossed over to the japs...
  97. New to the Civic world
  98. Has anyone installed a long Range Fuel tank/Auxiliary fuel cell?
  99. 2000 civic lx crank no spark
  100. 4-2-1 headers
  101. Anybody know by 5 speed conversion??
  102. Power Outlet Jammed?
  103. Build a B16A2
  104. gas question
  105. 220,000 miler no start
  106. Swapped same civic engine but have a problem
  107. power supply
  108. Mysterious liquid...
  109. A rumble from the CVT - bad or badder?
  110. Tastefully Modded Civics
  111. Car starting/ Gas types 2000 SE
  112. Wanna paint your lip or skirts yourself?
  113. 1998 Honda Civic EX Coupe
  114. Issues with 2000 Civic Ex
  115. Engine swap? What are the benefits/options? 98 dx
  116. B16a engine
  117. water in my aftermarket projector headlight
  118. MT to At swap
  119. How often do you guy adjust your valves???
  120. z6 head swap
  121. Ask your intake questions here!
  122. Installing a Short Ram intake on 2000 ex. (NEWBIE)
  123. front bumper bracket
  124. K20a Engine Help and Questions
  125. Installing short Ram intake HELP 2000 Civic SE
  126. looking for a used intake, anyone selling one?
  127. 6th gen body what wheels to get
  128. Transmission Noise?
  129. front right speaker not working
  130. 97 Civic Transmission and other problems need diagnosis for DIY
  131. 2000 ex engine problems
  132. 2000 honda civic lowering help
  133. 2000 honda civic lowering help
  134. Honda Civic Customization
  135. 2000 HX 49 EPA or CA?
  136. Fram Air Filters
  137. level to check tranny fluid?
  138. camber kit
  139. windshield wiper not working
  140. Window Motor/Regulator?
  141. What's the normal RPM at idle when engine is warm?
  142. CEL codes 72, 73, and 74... Engine shaking !
  143. headlight ?
  144. trunk lining replacement
  145. Where to get new floormats for a 99 Civic coupe?
  146. Oil drip after oil change? Fram filter?
  147. Full Type R Lip Kit for $200 Shipped
  148. manual transmission question
  149. Any ideas???
  150. jumper plug /diagnostics plug
  151. Fuel Gauge problems
  152. air intaketemp sensor
  153. Newbie/ 99 Civic EK or EJ??
  154. Newbie/Tie Rod Question
  155. Ignition timing drops?
  156. low rpm reading on scanner
  157. Bad Compressor?
  158. Civic SE anyone?
  159. Tail Lights, Turn Signals and License Plate Light are out.
  160. 99´ Honda Civic Center Dash Bezel
  161. 2000 Civic EX Power Window off track
  162. 1997 Civic stalls/rough idle.
  163. Best business/place to order an engine swap from??
  164. Need some insight on a '00 something haha
  165. 98 civic power locks issue
  166. exhaust
  167. AWD Civic conversion to 6th gen Q's.???
  168. Smokey the Honda. d16y7. Bad Timing?
  169. D16Z6 Head on a D16Y8 Block??
  170. 98 LX doesn't start
  171. fuel issue ?
  172. rev problems and check engine light
  173. Low idle persists after IACV cleanup and new PCV valve
  174. Cracked Exhaust Manifold
  175. Hesitation Upon Acceleration
  176. 99/00 sedan tail lights bolt on to 96-98 sedan?
  177. help greasing bushings
  178. 98 civic leather seats?
  179. What is this part?
  180. Please help 96 civic stalling out.....
  181. leather seats for 98 civic??
  182. plz help me
  183. Engine mount bolt removal problems (for drive belt replacement)
  184. d16y5 help
  185. squeek squeek
  186. d16y7 with pj2-2 head
  187. Wiper issue
  188. d16y4 engine swap???????
  189. 2000 Civic Ex Stereo Code
  190. mugen lip
  191. Swimming Pool in Trunk!
  192. Rim sizes for a 2000 SiR
  193. Head Swap
  194. 4 wheel disc
  195. have fuel to the rail, still not starting
  196. Harsh downshift during uphill climb
  197. lotek suspension
  198. Turbo Help Needed
  199. SRI install
  200. 98 hatch battery drain issue
  201. Removing and cleaning liquid spill underneath the shift knob
  202. 2000 EX computer problems
  203. Angel Eyes and HID Wiring?
  204. 99 Bumper on a 97?
  205. info needed asap
  206. 96 civic hb pics lets see them
  207. Deal or No Deal?
  208. ECU and air pods problems...info needed
  209. how to take off the center trim piece.
  210. Paint Stock Side Skirts?
  211. Cracking noise
  212. splash shields? please help
  213. Civic 97 Vti choke problem
  214. motor and transmission swap
  215. plz help anyone from central pa
  216. Very low idle. Pumping brake kicks it up. What's going on?
  217. 1998 Civic EX Wheels
  218. 99 Civic Manual Problems
  219. Valve cover??? Help
  220. k&n typhoon sri on 98 civic dx
  221. D16Y8 auto to manual
  222. My 2000 civic ex
  223. SOHC virgin
  224. Strange Noises!
  225. Amp Install With Stock HU and Aftermarket Speakers
  226. Power windows
  227. Where is the fuse?
  228. Another new guy
  229. Tranny pops out of 2nd gear - newbie and I did a search!
  230. 2000Si Bridgestone Potenza RE960AS PP Would These Be A Good Match?
  231. 2000Si Bridgestone Potenza RE960AS Pole Position Anyone Have These Tires?
  232. Couple problems with engine swap 01 engine in 96 EX
  233. Power Steering Pump bad? this would only happen to me
  234. Parts/materials needed to replace timing belt and water pump
  235. short ram:AEM or Weapon R Dragon
  236. stereo upgrade
  237. Aerodeck
  238. 1998 Auto (US) DX (CA) LX Low Gas Mileage
  239. Steering wheel jerks to one side
  240. How to know which Brain(ECU) goes with which Engine????
  241. Cel p0141
  242. which brand short ram intake?
  243. ECU And Wire Looms Query????
  244. 2000 Exhaust
  245. short ram or cold air?
  246. Upgrade air induction & exhaust options
  247. '97 Vtec grinds into 4th Gear at high rev
  248. 2000 Civic door won't open
  249. Window/Door Problem
  250. Completely Disscouraged
