2000 Civic EX Power Window off track
Old Mar 24, 2010
ianduh's Avatar
ianduh is an unknown quantity at this point
The driver's side window will roll down fine but about 3/4 of the way up stops, its outside of the rubber seal and you can tell its rolling up at an awkward angle. Could anyone give me some help removing the door panel and just getting the window back on track, im low on funds at the moment so im just looking to get the window back on track and up, and fixing the problem at a later date, thanks.
Old Mar 24, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: 2000 Civic EX Power Window off track
Very typical problem. Basically your regulator might of snapped and typically that need to be replaced, also the run channel prob needs to be replaced that is not letting the window back up. I would first check the regulator if that is ok then try to get it back in the run channel and leave it up.
You will have to take the door panel off, and look how it runs into the channel.
Take a look:
http://autorepair.about.com/library/faqs/bl068d.htm
Old Mar 24, 2010
ianduh's Avatar
thanks a lot for all of your help, possibly a stupid question but i dont know too much about cars. how would i know if the regulator were good or bad?
Old Mar 25, 2010
civicpapi's Avatar
If you take it apart, and it is snapped broken. The regulator is pretty cheap for the civics, many times you can get the motor and reg together for a good price. Just a bitch to replace. The run channel is a different piece as seen in the diagram above. I would do it yourself unless you have some good mechanical knowledge.
Old Mar 26, 2010
ianduh's Avatar
thanks a lot for your help, the regulator was the problem.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
silvervtec01
Nov 4, 2001 06:56 PM
