power window problem
Old May 5, 2010
kioto1914's Avatar
kioto1914 is an unknown quantity at this point
hello everyone, i need some advice, i have a 97 and have on the drivers side 2 buttons for the drivers side window and the passenger but even thou i can open the passenger side window from my side i cant open the drivers side, when i press the button the window does nothing, no noise at all, any suggestions would be great
Old May 6, 2010
Re: power window problem
can try and open the switch for cleaning, alot of times dirt and black stuff builds up and the components dont make contact.
Old May 6, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Do you have a 2 or 4 door?
So, what you are saying is the passenger side switch works the window but not the drivers side? Interesting many times if the master (drivers) goes then sometimes you can not work the passengers side from that switch either. Like gear said try to clean the contacts inside the switch, but it could be a bad switch.
Old May 28, 2010
iddude313's Avatar
iddude313 is an unknown quantity at this point
Hi.
I seem to be having the same problem.
Driver's window sometimes works and sometimes not.
But all the passengers windows work.
Can I buy a replacement switch and do it myself?
Thanks.
Old Jun 9, 2010
msusanka's Avatar
msusanka is an unknown quantity at this point
check the wires between the fender and the doors.
a lot of times they come out of the connector at the door and need to be re-pinned.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
