Harsh downshift during uphill climb
Old Mar 12, 2010
chris0628's Avatar
chris0628 is an unknown quantity at this point
hi guys.. i have a 2000 Civic - EXI (D15Z4 Engine) with conventional 4 speed automatic. lately i have noticed that during a uphill climb the AT downshifts harshly with a bit of a delay as well.....
the ATF has been changed on time, the car pulls well & downshift is smooth when driving on a level surface......
what could be the issue here ?
Old Mar 12, 2010
Shade's Avatar
Shade is an unknown quantity at this point
Re: Harsh downshift during uphill climb
you may have to take her in for an inspection. i have a CVT and it dont shift so i dont know how the auto feels.
Old Mar 12, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
What fluid was used? I noticed rougher shifting in my Civic and my wife's Accord with non-Honda ATF along with increased wear (many times the amount normally on the drain plug magnet).
Old Mar 13, 2010
chris0628's Avatar
i used the genuine ATF from the agent....the shifting is smooth except when I'm going up-hill & it down-shifts
Old Mar 13, 2010
ScottDR's Avatar
That's most likely a feature of the transmission as it has grade logic. It's a noticable shift instead of almost imperceptible.
Old Mar 14, 2010
chris0628's Avatar
Are you saying that this is normal ?... but how come it only happens sometimes... and from what i noticed.. only from 3rd to 2nd
Old Mar 14, 2010
ScottDR's Avatar
It's most noticable because of the large change in gear ratios from 3-2...and is only sometimes due to ideal conditions for them. I'd say it's normal, but I'm not sure how bad you are talking either.
I'd go back to the 5G always harsh shifting in a heartbeat.
Old Mar 14, 2010
chris0628's Avatar
5G ?
u dont think this is normal cos i can hear the thud during the gear change if i put the shutter down
Old Mar 15, 2010
ScottDR's Avatar
A thud may be indicative of a broken motor mount. Check them all out, it may be the entire problem.
Tyler93
Mar 20, 2016 09:03 PM
Shadowbandit
Wheels and Tires
Sep 16, 2015 09:34 PM
tommycanada
Sep 5, 2015 04:59 PM
Kcpowerhouse
Aug 25, 2015 01:15 PM
cwisenbaker06
Aug 19, 2015 04:29 PM
