fuel issue
Old May 8, 2010
kookoo's Avatar
kookoo is an unknown quantity at this point
Exclamation fuel issue
Ive been unsuccessfull diagnosing my 98 civic ; replaced, cap, rotor, plugs battery,checked for fuel pressure from filter;seemed good but still not starting.Origanally only a cold weather problem now full time. Please help.
Old May 10, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
Re: fuel issue
Well, we need more information. Did you check the fuel pressure with a gauge? If so, what PSI was it showing? Also, did the pressure peak then fall back? Could be the fuel pressure regulator. So as you see, we need much more information on what the problem actually is. Is it just cranking longer than normal? Or is it completely unstartable?
Old May 10, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: fuel issue
either a fuel or spark problem. do you have spark? Any cels?
dpru
May 26, 2015 07:01 PM
werdnahall
May 17, 2015 11:37 AM
McD
Apr 29, 2015 03:50 PM
McD
Apr 22, 2015 05:28 PM
PerfectD3
Feb 17, 2002 03:59 AM
