jumper plug /diagnostics plug
Old Mar 28, 2010
SirCharlo's Avatar
SirCharlo is an unknown quantity at this point
Hey guys,
where is the diagnostics plug for a 96 civic lx located ? can,t for the life of me find it, and it's dark as hell !
Thanks
Old Mar 28, 2010
SirCharlo's Avatar
Re: jumper plug /diagnostics plug
damn ! I think i just shorted something.
I saw a spark, as i was messing with the 16-pin underneath the steering wheel.
I was trying to get my cel to flash the appropriate codes... But that's another story.
Now my the-key-is-in-the-ignition-and-the-driver's-door-is-open chime doesn't work, neither does the overhead light, even when in the on position...
please help !
Old Mar 28, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
please help !
You might of blown a fuse. As for jumping for the CEL that I believe is done at the computer not the OBD port.
Old Mar 28, 2010
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
cel flashing in the obd port is only on 7th gen civics. on an 6th gen its a blue or gray 2 pin conector between the glove box and pasenger door. under the dash. might be slightly behind the carpit.
as for the spark if u conected pin 16 to gnd then yea u shorted out the fuse and need to replace it. i dont know on the earlyer civics but check the backup fuse or all the fuses in the under the hood fuse box.
Old Mar 29, 2010
SirCharlo's Avatar
That's what I though, so I removed the passenger kick panel, but I could,t find the plug...
It's not supposed to be connected to anything, right ??
Where exactly is it ?
Old Mar 29, 2010
SirCharlo's Avatar
Yeah, i changed the "interior lights" fuse and that's fixed.
I'm still at a loss to find the diagnostics plug, though...
Is it under the glove compartment, under the kick panel, or what ???
Old Mar 29, 2010
civicpapi's Avatar
Go to the pass side, get on the floor and look to the kick panel under the glove box. I think you need to remove the platice cover and pull some carpet back to find it.
Old Mar 29, 2010
DieMaster's Avatar
look here. it's got pics and evreyting.
http://www.honda-tech.com/showthread.php?t=1901557
Old Mar 30, 2010
SirCharlo's Avatar
Ah ! I finally found it !
It was actually hidden behind the ecu, so I had to remove it before I could access the jumper plug.
But with all your help I finally did it !
It flashed some codes, but that's for my other thread...
Thanks again for all your help !
SimpleUser
Apr 24, 2021 02:54 AM
fecrni
Aug 8, 2015 06:15 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
jzhartman
Jul 9, 2015 04:56 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
