Valve cover??? Help
Old Mar 4, 2010
cagcivicokc's Avatar
cagcivicokc is an unknown quantity at this point
Valve cover??? Help
I'm getting a turbo for my 2000 civic ex abd I'm wondering if I should get a new higher compression valve cover(head)
I have a d16y8 sohc block and valvecover(head)
but if I run 15psi would it be a must have to get a new head like a mugen one or something?
Old Mar 5, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Valve cover??? Help
You do not want to have higher compression which can be dangerous with a turbo. Forced induction generally requires lower compression to prevent pre-ignition.
Old Mar 5, 2010
02civicsi02's Avatar
Low and slow!
With a turbo you want low compression not high compression. And you will not need to get a whole new head. With 15 psi you will need to upgrade the valvetrain (valves, springs with retainers, cams, cam gears maybe) and just getting some low compression pistons and rods. But there is also more to it to. Like injectors, fuel rail, blah blah. Just make sure you get it tuned good.
Old Mar 5, 2010
Alright thanks
just got new spark wires and plugs today
atleast it runs better for now
Old Mar 6, 2010
04 Honda Civic's Avatar
Valve cover is NOT the same as the head just so you know
Old Mar 6, 2010
Saroset's Avatar
Saroset is an unknown quantity at this point
Like they said, there's a lot of stuff you need to upgrade before you slap a turbo on. D16Y8 stock parts literally start breaking once you hit 200hp.
Old Mar 6, 2010
89CRX's Avatar
89CRX is an unknown quantity at this point
All answers are correct here. Do not put a high flow cover low compression only unless u wanna sell it to a beaner as a parts car.
Civic15
18
Sep 19, 2017 07:48 PM
Misfit2613
Jul 30, 2015 09:49 AM
cukaracha
30
Jul 26, 2015 12:01 PM
hoofboy
Jul 17, 2015 04:27 PM
General 7th Gen
Jul 9, 2015 10:17 PM
