water in my aftermarket projector headlight
Old Apr 11, 2010
98dx's Avatar
98dx is an unknown quantity at this point
somehow i got water in my aftermarket projector headlight...it makes the hids and halos look horrible and i want to get rid of it...any ideas?
Old Apr 11, 2010
Re: water in my aftermarket projector headlight
Let 'em dry out naturally or open 'em up and dry them out, then re-seal it with some silicone or RTV..
Old Apr 11, 2010
dnice78's Avatar
dnice78 is an unknown quantity at this point
<--Projector hater, but ya riceboy got ur back
Old Apr 11, 2010
its very common to leak because they are not careful how they put sealant around them. gaps in the seal will cause leaks. pop the lights open and add more butyl to the channels. its better to add a bit extra and squeeze it out while clamping them back together that can be removed. the butyl ribbon stuff is just 3m windoweld from the auto store. good stuff. and use heat gun to open and close the lights. it makes the sealant softer.
Old Apr 11, 2010
98dx's Avatar
alrite thanks guys..and to gearbox--wats the channels??
Old Apr 12, 2010
ztoundas's Avatar
ztoundas is an unknown quantity at this point
i got water in mine soon after installing it, but after vacuuming it out (i removed the blinker bulb and stuck a vacuum hose up to the opening, it worked nicely) the water hasnt returned. if they are fresh installs, it may be from manufacturing.
Old Apr 12, 2010
channel i mean the groove where the two halves of the headlamp come together. there is already some sealer inside there but usually the factory does not put enough and you have gaps.
Old Apr 13, 2010
98dx's Avatar
i heard to drill tiny holes on the bottom where the water builds up so water can get out. put silicone over the channels and use a hair dryer on the outside of the headlight...will this work? its easier then takin out off the bumper taking out the headlight unsplicing the halos wires and then drying it out
Old Apr 14, 2010
BlueEM2's Avatar
Whachya lookin at?
^ That destroys the headlight. It's tough to seal that hole and drilling it will not get rid of the condensation, it will only get rid of the water. So they will still look like crap. Do it right and fix the headlight.
Old Apr 14, 2010
yeah you really need to stop the water from coming in.
Old Jul 21, 2010
kbook's Avatar
kbook has a spectacular aura aboutkbook has a spectacular aura aboutkbook has a spectacular aura about
Gearbox,
What a classic. Now's my turn to drain the water out of my passenger headlight. After the heavy rain, my headlight looks just like a bottle of cold beer sitting on the table for couple hours.
so I should use the the silicon or RTV to reseal right? What does RTV stand for? which one is better ? Thanks
Old Jul 21, 2010
Try and find some of that 3m windoweld. that stuff works awesome. I couldn't find it in any local auto parts store, so I bought some off amazon.com.
and RTV stands for "Room Temperature Vulcanization" and it's a type of silicone adhesive/sealant
Old Jul 22, 2010
kbook's Avatar
Thanks Riceboy, I will check it out at the auto store.
Old Jul 22, 2010
silicone will not seal a headlamp. it does not adhere to the rear PP (polypropylene) plastic. and if you put it between the halves, it will just make a mess and never dry. the 3m windoweld ribbon is soft butyl on a roll that will stick right away and compress when you clamp the pieces together, so you can peel off the excess. its also fully waterproof and all oem headlamps are sealed using this type of stuff.
Originally Posted by kbook
Gearbox,
Old Jul 26, 2010
kbook's Avatar
Thanks again Gearbox. I will have it ready next time if i need to open them. However, after I took the headlight off, I did not take it apart though, I dumped the water out via the hold between the case and the inner which has piece of rubber seal around it. Apparently, the rubber seal did not seat properly and it was the root cause that allowed water to get in. So I blew hot air (hair dryer) into the headlight and dried it out.
the good part, I do not need to open the case, the bad, it left lots water spots T_T not bad but at least it is dry now. : )
honda.lioness
16
Feb 10, 2017 10:53 PM
JKWood
Jul 28, 2015 03:45 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
