- Dome light not working properly
- EK3 JDM Diagnostic connector identification help
- WTB civic headlight grommet set (dust cover)
- no.1 cylinder question
- I need Some Honda civic 96 parts.
- h22a ek boost build
- V-tec not kicking?
- bought 97 civic with d16y5 and...
- Ignition alarm...
- Subframe Rotted
- Rear plastic panel 3rd brake light removel?
- tryin somethin quick
- Type R or Mugen Front Lip?
- 97 EX ugly gap between hood/grill
- 97 civic ex passenger window comes off track
- How much would you pay for a 97 Honda Civic HX?
- 97 civic ex transmission sensor?
- my car wont rev over 3k
- I need help
- Is this a good idea???
- Radiator
- New To civic
- Best engine for my 96 civic lx automatic?
- More Aggressive Civic Front
- Crankshaft Bolt Torque
- Pricing Fenders
- Product Hunt Down!
- rear visor on a 99 coupe
- Couple Q's? in a dilemma..
- Might buy a 6th gen, need help
- ebay muffler
- JDM D16 Wrong Crank?!
- Need help with trans removal
- Might get this car for my 1st one!
- Might buy this car! Plz answer q's
- HELP - keyless entry
- best way to go about reinstalling pwr steering?
- Extended Ball Joints: Why they're good, and bad (with pictures! :D).
- Ideas and advice needed
- What have you done to your engine?
- Pleas help need advice before i make a purchase!!
- EM1 Clean title search: Go salvage?
- Changed to NGK wires and spark plugs..pic
- Noisy acceleration in 2000 Civic EX (automatic)
- 94 auto trans into 96 hatch
- Replaced cracked Exhaust on 1996 Civic DX...
- Trunk Carpet Fasteners
- Complete BEGINNER!
- best exhaust for a b20vtec?
- shimmy and steering wheel wobble at 70+ mph
- 96 civic knock wierd
- Clutch newbie. Help?
- 97 Civic EX overheated & wont start
- Another NOOB
- Camber Kits and Tow Fa Sho!!!!!
- Cable for Trunk and Gas Tank Door
- Yet she still runs like she just came off the lot!
- 2000 civic coupe rear ended
- Where can I find the VIN nubers on 99 civic motor?
- Parts wanted for my 1996 CX hatchback
- "Stop Leak" products any good?
- Stereo question
- Stolen: 1999 honda civic lx
- please help with identifying something in engine..
- How many miles (on average) do the 6th gen transmissions last?
- 96 civic jdm vtech swap with stock computer
- Modding a completely stock 1998 civic ex, thoughts?
- I dont get this..anyone else getting 60mpg out of their civic?
- suspension noob
- 00 civic won't start...
- 2000 civic exhaust
- High Idle
- oil pan difference?
- 98 Civic EX Seafoam?
- Trouble Bolt on Thermostat Housing! Help! Radiator Fan HookuP???
- 96 civic DX
- 2000 SE 72K kms maintenance / Do it or NOT?
- Belts????
- 6th gen auto tranny behaves like it has 5 gears
- 98 civic ex transmission swap
- Big Transmission Cooler for 97' Honda Civic EX Auto
- Will a rear lip from a 99 4dr fit on a 98 Coupe?
- Changed plugs, started great, quit after 5 mins, now won't start
- Civic Newbie
- Gears are hard as F**K!
- Squeaking in Front end
- 2000 Civic Si Questions
- What part is this??
- Simple question about the oil dipstick
- Who has the most miles on their automatic?
- '99 Civic Hatchback DX (Canada)
- Steel Oil Pan on 98 Civic HX D16Y5?
- 2000 Civic VP Code P1457 205,000 Miles
- 2 steps forward, 4 f***in steps back
- New paint job.
- Startin' Out
- How much should I sell my 1996 Coupe EX
- 00 SI suspension!!!!!!!
- D16Y8 Build Questions
- 98 with Manual Transmission.. oil question.
- Can't find 98 Civic Si Coupe parts!
- Cig lighter and hvac lights not working...
- What???? Eibach Prokit doesn't work with 205/55/15!!!
- EM1 wheels.
- Something a little different from everyone els....
- Not sure what to do! Need some help
- D16 Help
- Climate control console
- Intermittent Speedometer
- Has anyone done any interior modifications?
- shaved door handles
- H22 install?
- Trouble Code P1456
- 98 civic ex trans swap
- Owning a 2000 Civic Si risky?
- Is E15 safe to use in 1999 Civic?
- Turbo kit for 2000 honda civic ex?
- Shaved Handles
- lets play "whats that sound".
- progress on the 6th gen
- Small mods ????
- auto trans reliability
- Help with honda
- Header for D16y7 engine
- New to the Forum with Questions!
- 99 civic lowering question
- 2000 Acura EL problem... help!
- valve cover bolt nut broke idk
- misfire at high rpms
- B series 70mm skunk2 megapower exhaust for sale
- Typical MPG of the '99 LX Civic (Automatic)?
- Suspension upgrade; Poly vs. Rubber
- 99 Si Grille Badge
- Redo Interior
- Ignition...key pls!
- how to disable the alarm on '00 civic si?
- Should I buy this honda civic?
- B16a stalling out problem
- Newb With Some Questions
- Confused Honda NOOB... need advice!
- Desperate for help! Dreaded P0335 trouble code (CKP - Crank Position Sensor error)
- Shaving the Badges
- Owners Manual 96-00
- compression check????
- Civic runs rough for first 10-30 seconds...then it runs normal.
- 1998 Civic Sedan 1.6l Automatic
- muffler/exhaust problem...I think. '00 civic si
- someone tell me what i got
- Radiator help
- HID Kit Upgrade
- bought my new 6th gen
- 98 SI questions
- thinking about buying a 2000 civic ex
- 1999 Honda Civic EX Painted trim -.-
- Looking to buy civic
- I have a question, 99 civic
- Does '98 integra gs exhaust fit '98 civic ex?
- spark plug gap and coolent leak!
- My new 2000 Si
- D16y8 build
- 96-2000 EX Black Spoiler and other parts for sale
- Body panel under tail light help
- Tightening up loose steering
- 98 Civic Radiator Fluid leak
- Need HELP!!!!
- First Car: 1997 Civic Coupe EX
- What to look for in a 6th gen?
- Replace the fuel pump for Civic 98
- shifting gears been acting funny
- first mod help?
- Back Doors won't open from outside
- 98 Civic LX 5speed stuck in reverse?
- 6th Gen Civic EX Modding
- i got situation
- i have a problem
- LED Lights for 98 Civic Hatch
- Control Arm Ball Joint
- CV Axle Swap
- 99 si bumper on 98
- Body work
- Light smoke headlights
- Upholstery seat question
- 1998 civic power surge
- 97 fit 99 headlight?
- new ej6! a 99 EX
- 99 civic suspension
- Installing a Short Shifter in an EX
- Need to find LED tail lights for 00 4dr
- Civic Auto to manual swap.
- Forza 4 pics
- oil pressure
- Just bought a 00 si
- What models/year struts fit a '97 hatch?
- Best way to lower a Civic
- D16y8 a defective block or something.??
- 98 civic ex, abs light problem.
- Which Engine
- Odd Civic problems
- Transmission cooler install
- 99HondaCivic KillSwitch HELP!
- 2000 civic speedometer & transmission problems
- trouble starting 2000 honda civic lx
- 1998 HX RPMs surge while accelerating HELP!
- Oil leak i cannot figure out
- An Oil leak that I can't see
- Best Theft Deterrent
- Clutch switch is keeping car from starting.
- Need help with my car stario.. pls help.. ty
- EK4 SiR Brake Help
- Rear Spoiler Question
- Rear Subframe Replacement
- Tokico Blue HP Struts/Shocks
- Honda Civic 98 Ex Rotor Screws HELP!
- Picture of d16y8 head with VTEC selanoid off
- pulling engine
- MPG not looking as good as I hear...
- What brand do you guys use for coolant?
- Tips on a 99 civic coupe
- starter solenoid help
- Looking for a 98 civic carbon fiber hood
- Another Old Guy with a 99 DX Hatch
- Need Help Identifying Motor Mounts for 2000 D16Y8
- Which Headlights to get?
- Bring a neglected Civic back to life.
- Blue GReddy box need cord!
- pulling motor, pistons, and rings!
- New to civics, looking to get one.
- Is this civic si vtec good to buy?
- the body parts?
- Is this 1997 Civic coup any good?
- exhaust swap cel possible fix let me know what you think
- 1998 civic dx Turbo?
- duckbill spoiler? help!
- 91 to 97 swap
- Driver Side Power Window Struggles Despite New Motor
- Replacing Steering wheel on 98 Civic
- Cool Swap? Or Just Fiction?
- 1997 LX air intake questions
- Ex h22a1 swap: HELP!
- '00 Civic EX with CEL
- How to upgrade from LEV to UltraLowEmissionVehicle?
- 2000 civic SE no spark!
- looking for jdm genius in orlando
- 00 coupe ex, horrible shutter on takeoff and rough ride
- Civic SRi Fabric
- Type R Rear H Emblem for EM1
- rear drum to disc brake conversion DIY?
- Just bought this 98 B20 Swap, opinions?
- Help Driver side Speaker Noise
- Need Turbo Help! Got Questions 98 Civic Si
