misfire at high rpms
Old Jan 12, 2012
TODoubleD's Avatar
TODoubleD is an unknown quantity at this point
i have a 1999 honda civic hx with a cat back exhaust and a short ram intake. i have noticed that i get an flashing check engine light in really high rpms on the highway. and it goes away if i slow down. what could it be?
Old Jan 12, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: misfire at high rpms
How high a RPMs..are you redlining it?
Old Jan 12, 2012
Gunner's Avatar
Also check the code..the ECU should store them so you can pull it still.
Old Jan 12, 2012
TODoubleD's Avatar
its has a p1399 pending code. and it happens around 5-6k rpms
Old Jan 12, 2012
Gunner's Avatar
i beleive that is a random misfire code..check your plugs and make sure they are gapped right and all that jazz..
Old Jan 12, 2012
TODoubleD's Avatar
i have checked them with in the last couple months and everything looked perfect.
Old Jan 13, 2012
Gunner's Avatar
It only does this when you run "really high Rpms"? How high are you talking?
I dont want to have you start checking and replacing peices in your ingnition system to find out its only coming on to let you know your abusing it
ZSKCivic01
Jan 29, 2002 06:09 AM
ripper
Jan 28, 2002 02:00 PM
Aznnp77
Dec 13, 2001 04:03 PM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
