91 to 97 swap
Old Oct 16, 2011
swagger9000's Avatar
swagger9000 is an unknown quantity at this point
91 to 97 swap
Is it possible to swap the motor of a 91' 5-speed civic into a 97' automatic civic? The 97 is a D16Y7 DX hatch and I am not sure what the engine model of the 91' is. The seller says its a D16Y7, but I'm not sure if that engine came withe the car.
Also, is it possible to put an automatic transmission from a D16Y7 on a block that had a manuel transmission?
Thanks
Old Oct 16, 2011
MindBomber's Avatar
Live for the Twisties
Re: 91 to 97 swap
No, you can't swap a engine from a 91 into a 97 because it's illegal.
Old Oct 16, 2011
lazlong's Avatar
Re: 91 to 97 swap
Look here for the engine code:
If it says D16Y7 then a previous owner swapped it in and you're fine to swap it in yours.
Old Oct 16, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: 91 to 97 swap
Pssh, that's not a reason!
Yep! But it's actually going to be quite difficult. It's a lot easier to go the other way around--you'll need to do some research to see what exactly you're going to need, but as far as I'm concerned it's not worth it.
Old Oct 16, 2011
MindBomber's Avatar
Re: 91 to 97 swap
I know, it's just the simplest one and I didn't feel like explaining the other difficulties with swapping a d16 to a d15..
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
