Help Driver side Speaker Noise
Old Sep 28, 2011
party_boy_bryan's Avatar
party_boy_bryan is an unknown quantity at this point
ok guys just installed a new head unit and a mono amp for my subs. The driver side speaker now has noise. When i took the fuse out of the amp power wire the noise stoped and all speakers preformed normaly but obviously there is no power to my amp for now. I had the power wire tucked under the trim, I moved it under the carpet closer to the ceter concel no change. I did not buy cheep wires any thoughts? I have a long ground going to my amp. could it be the amps ground? Its only this one speaker when the power wire is connected.
any thoughts would be great!
Old Sep 28, 2011
GolNat's Avatar
Prelude Owner
Re: Help Driver side Speaker Noise
Yes it could be the amps ground and that is where I would start. It's suppose to be as short as possible and have a good connection. Make sure you sand paper any paint or anything that is on the body so that you can get a good connection to the bar metel of the car.
Old Sep 28, 2011
GolNat's Avatar
Prelude Owner
Also you should always run your 12v power cable separate from your RCA audio wire to keep out any excess noise.
Old Sep 28, 2011
ok guys this really stinks, I do have rca cablese routed on the passenger side far away. Also i am just using the power from the deck entill my 4 channel amp comes. ok back to the issue, no noise with amp off. when the amp is on (power in the line going back to it) I get a noise only in the on position, and no noise in the acc position, when the engion is running it is much worse and I get another squeal from what seams to be around the gauge cluster. It gets much worse as I accelerate and the speaker goes crazy. I took the inline fuse out of my power wire and the speakers perform normally again, plz help. I tried shortening the ground.
Old Sep 28, 2011
GolNat's Avatar
Prelude Owner
Since it gets worse with engine on and when your accelerating you are definiety getting noise from something. Did you hook up your ground from the head unit to the chassis of the head unit?
Old Sep 29, 2011
omg Im a idiot lol so I ran my front and rear channel rca's also so when i get my 4 channel amp I dont have to pull the head unit back out a bit of a pain on my model. so I took my car to a audio shop and paid then 50 bucks for them to tell me my rca was touching my power block LOL It was loose rolling around in my trunk. Next time Ill tape my ends till i plug them into my 4 channel amp lesson learned!!
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
ashlava71
May 16, 2015 12:54 PM
Supramk3
May 11, 2015 07:55 PM
ej8
Apr 13, 2015 06:36 PM
