oil pan difference?
oil pan difference?
Ok, I am a bit confused on the no need for an oil pan gasket on the Civic EX model. I just picked up my 2nd civic, 2000 EX 5 speed, the first one was in college and early 80s hatchback from Canada. I noticed there is a small leak from the front of the oil pan, or appears to be. So what is the difference between the DC and an EX of the same year? Is it the motor? Mine does not say VTEC or anything like that. It just has HONDA on the valve cover. Is this 2000 a d16y8 motor? Looks like I have to replace the pan due to the previous owner over tightened the plug. And in the process of removing it, some threads came with it. Any info is appreciated. THANKS!
Re: oil pan difference?
Stock motor for 2000 EX is the Y8. Look here to confirm:
Then go here and enter the correct model and year: http://www.hondaautomotiveparts.com/
And yes the EX has a different pan than the other models. The V-TEC engines always do.
It is the D16Y8 engine. I see by the way the diagram looks I do in fact need a gasket. Guess I was just confused why someone say that it doesn't. Seems odd that it wouldn't need one. Thanks
Red_Chaos1
Jun 21, 2015 01:12 AM
Vaguexo
Jun 13, 2015 04:11 AM
jmdcivic
May 20, 2015 09:52 PM
