- new member
- best lowering kit to get for a 98 honda civic lx?
- Odyssey shift knob on 99 civic ex automatic... Will it work?
- WHERE TO START?? any suggestions would be nice!
- ? about check engine code p0135
- Horrible gas mileage
- i screwed my 2000 si vtec:( (not the car, the vtec)
- Owners Manual - 1998 Honda Civic Sedan VTI Automatic
- signal light problem after a bump in the rear
- Grinds in 3rd gear going over 4k rpms
- Please i need answers
- 97 oil leak
- a/c kits?
- Motor/Tranny issues Help please
- Driver Side Manual Window Regulator
- 2000 SiR engine rebuild/upgrade?
- engine misfires
- bumper isnt flush....
- stalling, pings, no power
- Alignment question
- Tires?
- header help
- Aem v2 intake
- 6th gen hatchback
- 1998 Civic LX turn signal issue
- problem with shifting
- Mirror actuator assembly
- Passenger side mirror an MOT
- need a shell
- 98 civic EX vertical intake manifold
- new to this site!!!
- injector ground on obd2-a?
- Is it bad to install a breather?
- Installed Intake now Knocking NOISE!! HELP
- 1996 Civic Coolant Leak
- Speedometer lag
- My civic 96 Exi 4-door sedan's battery drains so fast
- 98 honda civic problem
- B16a2 into 1996 ex coupe
- LED consoul lights
- gurggle noise when i shift into first
- Header and Exhaust System
- Strange starting problem
- Interior lighting problem
- 1.4S Civic 2001 windscreen washer problem!!!!!
- 98 EX rpm issue
- Timing belt kits...
- b18c a/c help please
- Need help!!! 2000 civic dx no heat
- Synchro Issue -- Synchromesh?
- 1998 Civic Si (Canada) charge problems
- My 2000 SIR
- Help!! :(
- Exhaust compatibility
- 98 Honda civic D16Y7 - is there a OBD2 port
- Check Engine Light Help?
- 96 civic trans fluid change
- 96-2000 civic automatic tranny issues?
- civic idle flucuating?
- 96 civic Electrical issue...need some help please!
- Best bolt on's?
- 97 w/ sohc having trouble getting started
- 99 power windows not working
- After market HID's burn stock housing?
- Bezel Question!
- Loss of power, slight tinking
- Nasty Rough Idle
- Will this 02 work for a 00' EX
- Input needed on rim color..
- copy key and transponder poblems
- New Subs...LOTS of outside rattling.
- Valve Cover?
- SRS 97 DX Coupe
- Swap or mod?
- New menber seeks advice.......
- Idle Air Control
- swap a H22A1 in my 98 coupe, good idea?
- Center console bulb replace DIY and others
- '99 civic emissions problems
- P2000 CEL on '05 HCH
- alternator?
- Prestone leak ?
- this always happens......
- Body Kit on 2000 Civic SI?
- Clutch Issues, 1999 EX
- 97 EX Coupe weekend project help
- ticking noise
- bad igniter/distributor
- Oxygen Sensors
- Hood release lever broke
- How to install Anzo USA Black Headlights
- audio questions
- Speedometer stopped working
- idle problem
- top of engine oil leak
- Trunk leak again
- 2000 Honda Civic Si
- 97 HX getting bad MPG
- body- frame question [problem from small collision]
- Irregular idle (rpm fluctuates) when on park gear and brakes applied
- CEL misfire on cyl 2 and 4
- Cupholder alternative?
- Help identify this pipe
- Hondata s300?
- changing suspensions
- And the idiot of the month award goes to...
- noob question about type r valve springs
- Rear ended today
- Help with '96 civic emissions
- hey guys......ive got a weird problem
- Motor swap!!!!!
- HELLO!!! Im new to this forum and i just wanted to say HI!!!
- 96 d16y8 with no set screw on dis rotor?
- Civic 1.6i SR Good and bad sides.
- boosting the 2000 si
- MSD Questions
- Hood Adjustment
- rough idle, tried everything.
- CEL Misfire Cylinder 2
- performance parts
- idle jumping
- 2000 Honda Civic Si wont start
- Good and cheap exhaust?
- Heat shield rattle.....
- intake swap
- civic cutting off
- New to Civics, need help.
- Strange lamp next to dimmer switch '98 LX
- jdm d15b in 96 civic
- Is this a 6th gen Civic?
- Radio in 98 ex question
- Battery Light Flickering Intermittently
- Oil disappearing! Where's it going?! Mystery...
- How hard is it to take apart the dash to replace with all LED's?
- Grr! What's that SRS light always doing on?
- Strange noise around 2500-3500rpms
- New to forum. Problem with stuck glovebox.
- What gas mileage mods can I do to my 6th gen?
- Need help with idling problems!!!
- Exhaust Question
- '96 Civic HB::Coolant Leak and Cooling Fan Not Working
- Alternator squealing
- 6th gen guys want a new style type R steering wheel badge?
- car bogs out at about 5000 in 2nd gear and same in 3rd help
- 97 Civic DX
- Honda Civic Trans Problems
- crank shaft pulley bolt
- 98 Honda Civic Automatic Trans Problem
- Fuel leak - DIY ?
- Vtec question!! Please help!!!
- Best, most reliable set of halo projectors for my '97?
- 98 ex overheating
- New to forum! Questions on my 1998 EX Coupe.
- Check engine light on.. Have codes
- d16y8 bogging out while accelerating
- Neon License Plate Frame Install
- 96 ex clutch noise, Help!
- advice for my 98 EX civic
- hopefully simple drumbrake Q
- 1996 SOHC VTEC auto trans problem
- 97 Civic Front Quarter Panel Removal
- vtec working?
- Strange hissing like compressed air
- Honda Civic - Intermittent startup problems
- Value of this Turbo Alch Inj 1996 Civic
- 96 D16Y8 to B18B1 Swap
- Locate the Power Lock GREEN/WHITE in Blue Harness HELP
- Shocks and Coilovers or Full Coilovers
- Problem - Clutch Pops
- Going to be replacing a D16Y7 - Advise?
- 2000 civic noise while turning right only? (sound clip)
- Climate Control Problem
- Changing the Ac belt
- Header Swap Issues
- 2k civic ildeing weird?
- 99 LX Surging...
- 2000 civic ex running problems
- Got Problems!
- Radiator issue
- How do you install alarm system 1997 CIVIC LX 4 DOOR
- Flowmaster series 60 muffler
- 1997 Civic Hatchback 1.4 Initial - Main Beam Headlights Not Working
- 0 RPM Dip
- Civic DX 97 - Spark Plug Tube Removal?
- 99 Civic D16Y7 engine gnarly knock at 25-3500 rpm's
- Air Intake Question on DX
- Runs rough in 1st and 2nd then fine after that
- Civic clutch kits
- Parking Light Not working?
- Broken Bolt
- Wanted: Stock Rear Shock/Suspension
- HO Altenator Question
- P0420
- P0135 driving me NUTS!
- Car wont start after sitting for 2 days
- 98 civic lx ignition switch
- 99 lx
- 98 lx ignition switch
- 2000 civic se tachometer
- How to reset the PCM on my 1998 Civic EX
- Fan System Problem
- Idle problems
- H22a?
- How to Determine Engine.
- Stock 1999 Exhaust Pipe Diameter?
- Intermittent Idle Problem
- 97 civic oxygen sensor question
- engine swap
- strange interior dome light issue at startup
- 1996 civic cx leak in trunk ( and paint job )
- Hello, Newb...
- radio relocation?
- Green drive light in dash go on and off
- 1996 Civic Radio Revamp Help [COMPLETED!]
- Rear, soft `thump thump' sound when braking
- VTEC VTI B18 Clutch pedal adjustment
- New....
- Newby to the forum...96 Civic EX sedan
- 2000 VTI revs fluctuate
- Civic Cluster Color Change
- vtec cutting off? HELP
- 1999 EX lacks power/acceleration
- Parking Break question
- How to replace Rear Back Drum
- New to the Civic Scene
- 98 HX wont start
- Replacing window regulator - tips?
- Spark plug installation torque specific?
- Transmission Bearing Noise?
- headlight problem
- Engine quits while driving
- Advice on Headlights Replacement
- rough idea on power??? random questions?
- Black mesh wheels?
- cheap mods
- Old Faithful Needs Attention
- need help! my center dash was stolen!
- rim offset?
- revs only until 4000rpm?
- B16a2 Valve Cover & Vtec Controller
- Cheap header?
- Headlight
- 96 JDM type-r bogging badly HELP!
- Project car help
- EX spoilers
- 18" Upgrade
- lookin to lower my 1998 ex
- Working on my 97
