b18c a/c help please
Old Feb 4, 2010
twign209's Avatar
twign209 is an unknown quantity at this point
has anyone done this before, im not sure which parts to use, i already have the a/c braket but idk which a/c lines to get which compressor evap condenser ......
i have a 98 b18c in my 97 civic with no a/c
Old Mar 11, 2010
sureshot1979's Avatar
sureshot1979 is an unknown quantity at this point
Re: b18c a/c help please
dude when they install the b18c in your civic did they take out ALL of the supporting hardware such as lines and electrical stuff like the condenisor relay near your washer fluid pump ,condeinser pipes, r134a lines, fuses ,relays, screw nuts and bolts ,alluimin pipes pressure swiches,fan condensor swicthes man the list goes on and on. because you can use all of the the stock stuff your car came with otherwise to do the whole car is going to be expensive. you might have to get a donor car first its cheaper that way
Old Mar 11, 2010
if you have a turbo DONT DO IT your car will run very very hot and that is when heads block and turbos start to warp and their may not be any room for your condiensor/fan
Old Mar 11, 2010
hey send me some pics of your engine bay!!!!!! i might can help you detailed if you can
jtcavey
Sep 30, 2015 02:18 PM
anubis62
Sep 27, 2015 12:56 AM
yyyktk1
Sep 12, 2015 04:02 PM
NROD315
Sep 12, 2015 02:46 PM
NROD315
Sep 4, 2015 09:22 PM
